Re: 904 aluminium drum ??s
[Re: DavidDean]
#885428
12/22/10 02:49 AM
12/22/10 02:49 AM
dartman366
Mt. Vernon, Ohio
Just my opinion, lot's of money for no real gain,more maintenance intensive and don't run one with a kevlar band,I have been running the stock drum's for ever, and had good luck with them.
[Re: olemopar]
#885430
12/22/10 09:42 AM
12/22/10 09:42 AM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
I run the A&A billet steel drum in the 904 in the Dart. I didn't want to have to change my fluid every 20 passes like they say because that is two races for me.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: @#$%&*!]
#885434
12/22/10 07:54 PM
12/22/10 07:54 PM
Posts: 9,863 MI, usa
dvw
MI, usa
Spinning cast iron at high speed is risky, that's why we get rid of the stock vibration dampers and flywheels. We'd probably wouldn't be able to run cast-iron crankshafts if they weren't contained inside the block, which makes for a good ballistic shield
Guess I'll stay w/ my modified stock unit Thanks
Can you be sure the modification didn't weaken the drum? The 904 doesn't seem to have a history of problems, how lucky do you feel?
You don't need a aftermaket drum for a 904. I ask it now. Has anyone ever seen an exploded 904 high gear drum? Not I. Doug
[Re: dvw]
#885435
12/22/10 08:28 PM
12/22/10 08:28 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
The next one I see will be the first!
Plenty of transbraked 904's running around...
[Re: tubtar]
#885438
12/23/10 05:01 PM
12/23/10 05:01 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
I discussed this with length with Chuck Lofgren before mine was built and I came away with the impression that it really wasn't necessary from a safety stand point. I would guess that if you are shooting for every last ounce of E.T. , it would make sense........but aluminum is way more maintenance.
I cant speak to a 904, but i can say that rollerizing my old 727 and adding an aluminum drum resulted in zero ET gain over the tranny that was in the car before that didnt have these mods added.
There was a post long ago about this and most if not all others reported seeing nothing ET wise as well with an aluminum drum....your results might vary.
Didnt see squat going from 8.75 to Dana either, Dana was just as quick.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
