Re: Cuda trunk wiring pictures [Re: 19cuda73] #885262
01/30/11 12:46 AM
01/30/11 12:46 AM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Harness picture
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: Cuda trunk wiring pictures [Re: 19cuda73] #885263
01/30/11 12:56 AM
01/30/11 12:56 AM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
I was curious if someone has diagram or a photo of the seat harness as it is installed across the floor?. Here's what I have right now?
1972 Corvette
Re: Cuda trunk wiring pictures [Re: 19cuda73] #885264
01/30/11 02:15 AM
01/30/11 02:15 AM
Wausau Wi
Convertcuda Offline
Convertcuda  Offline
Wausau Wi
Snoopy nice job on the pics. Do you have any reference shots for convertible cudas rear tailight harness routing and rear pump harness? Also, I know that there are little loops that hold the harness by the trunk gutters. Any shots for refence on that also. I see that some converts have one loop and some have two loops.
Thanks Ken
Re: Cuda trunk wiring pictures [Re: Convertcuda] #885265
01/31/11 12:14 AM
01/31/11 12:14 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Re: Cuda trunk wiring pictures [Re: Snoopy] #885266
01/31/11 12:14 AM
01/31/11 12:14 AM
Snoopy Offline
Snoopy  Offline
Re: Cuda trunk wiring pictures [Re: Snoopy] #885267
01/31/11 12:57 AM
01/31/11 12:57 AM
Wausau Wi
Convertcuda Offline
Convertcuda  Offline
Wausau Wi
Thank-you! You are man with the great pics. My car is getting closer and closer everyday to getting done. Wish I could find those last few parts.
Ken
Re: Cuda trunk wiring pictures [Re: Convertcuda] #885268
01/31/11 01:07 AM
01/31/11 01:07 AM
Snoopy Offline
Snoopy  Offline
Re: Cuda trunk wiring pictures [Re: Snoopy] #885269
01/31/11 01:11 AM
01/31/11 01:11 AM
Wausau Wi
Convertcuda Offline
Convertcuda  Offline
Wausau Wi
Thanks Again - Would you happen to have any of the pump cylinder oil lines routing.
Re: Cuda trunk wiring pictures [Re: Convertcuda] #885270
01/31/11 01:37 AM
01/31/11 01:37 AM
Snoopy Offline
Snoopy  Offline
This is all I could find, it seems to be a generic picture. It is from the 70 Plymouth Factory Service Manual.
I have seen a really good picture of the plumbing on Moparts, but didn't save a copy of the picture. Maybe the member that posted the picture will repost it.
Re: Cuda trunk wiring pictures [Re: Snoopy] #885271
01/31/11 01:43 AM
01/31/11 01:43 AM
Snoopy Offline
Snoopy  Offline
From the 70-71 Factory Parts Book.
Re: Cuda trunk wiring pictures [Re: Snoopy] #885272
01/31/11 01:50 AM
01/31/11 01:50 AM
Snoopy Offline
Snoopy  Offline
2
Re: Cuda trunk wiring pictures [Re: Snoopy] #885273
01/31/11 01:50 AM
01/31/11 01:50 AM
Snoopy Offline
Snoopy  Offline
Closeup
Re: Cuda trunk wiring pictures [Re: Snoopy] #885274
02/01/11 02:27 PM
02/01/11 02:27 PM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
I don't mean to hijack this thread, but since I am doing my rear harness right now I thought I'd ask:
What size (and what wattage) bulb is supposed to be used for the license plate light? The bulbs for the tail lights fit the socket, but you'd have to disassemble the housing since the hole isn't big enough to fit the bulb through and that just doesn't seem right (plus it would be too light).
Thanks in advance.
Re: Cuda trunk wiring pictures [Re: PAINT IT BLACK] #885275
02/01/11 02:59 PM
02/01/11 02:59 PM
Snoopy Offline
Snoopy  Offline
#67 bulb
Current: 0.59 A
Voltage: 13.5 V
Power: 7.965 W
LCL: 20.60 mm
MOL: 36.56 mm
Diameter: 19.0 mm
MSCP: 4.00 MSCP
Avg. Life: 5000 hours
Filament: C-2R
Bulb Shape: G-6
Generic Part No: 67
Base: BA15s
Re: Cuda trunk wiring pictures [Re: 19cuda73] #2475121
03/31/18 11:47 PM
03/31/18 11:47 PM
IL.
SIXPAC Offline
SIXPAC  Offline
IL.
Any way to be able to view the photos and illustration pics that were attached to the posts in this thread? They all seem to dead links. I would really like to see the assembly manual page showing the Cuba driver side tail light wiring and ground wire.
Re: Cuda trunk wiring pictures [Re: SIXPAC] #2475128
04/01/18 12:01 AM
04/01/18 12:01 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I see this is your first post welcome to the board...Every one is opening for me...Click on the link, open or download the attachment and view...There's many knowledgeable members here if in the future you run across an old thread and need info/pics on the subject using the new forum format just ask and we can post the info... In any case here's what you're looking for I pulled them for you...
6373136-70-71CudaTrunkWiringPartial.jpg6373898-70CudaTaillightandSidemarkerGround.jpg6401225-WheelhouseWireRouting.jpg
Re: Cuda trunk wiring pictures [Re: 19cuda73] #2475130
04/01/18 12:06 AM
04/01/18 12:06 AM
Harrisburg, Pa.
Harrisburg, Pa.
And for your viewing pleasure here's a pic of the actual ground wire in question it measures 16 inches long..
Re: Cuda trunk wiring pictures [Re: 19cuda73] #2476167
04/02/18 03:43 PM
04/02/18 03:43 PM
IL.
SIXPAC Offline
SIXPAC  Offline
IL.
Thanks for the pic and scan!!
Does anyone have an original spare one?
Was this ground wire used on 1971 models as well?
Does the orig. wire in the pic have the part # printed on it? It also looks like it has 1/4" holes in the terminals, aren't the studs this wire attaches to only a #10 thread size??
A friend was the original owner of an EARLY 70 Cuda, he said some time in Feb. 1970 the dealer added this wire to his car due to back-feed problems in the lighting circuit that he was experiencing. It appears that this wire may have been installed at the factory sometime during mid production and that there may have been a TSB for the addition of this ground wire to earlier cars by the dealers.
Lastly, Does anyone really have any idea if or when the Assembly manuals will be available?
Re: Cuda trunk wiring pictures [Re: 19cuda73] #2478045
04/05/18 09:30 PM
04/05/18 09:30 PM
Harrisburg, Pa.
Harrisburg, Pa.
Here's another old thread on the ground wire with some info...Keep in mind if the wire was added by the dealership through a TSB then unless current owners had the vehicle from new then the SPDs really mean nothing other than speculation... ground wire thread
IIRC the wire did have some script/part number on it.
Since you can't pull the pics from the old formatt...Here's the 2 pics from the thread showing the referenced "survivor" it gives the info on the different sized terminals you asked about...
