Re: Cuda trunk wiring pictures
[Re: 19cuda73]
#885263
01/30/11 12:56 AM
01/30/11 12:56 AM
Posts: 1,300 Washington
19cuda73
Washington
I was curious if someone has diagram or a photo of the seat harness as it is installed across the floor?. Here's what I have right now?
1966 Charger 383 4 speed (Black with Red interior) 1973 Cuda 340 4 speed (Lemontwist) 1972 Corvette
[Re: PAINT IT BLACK]
#885275
02/01/11 02:59 PM
02/01/11 02:59 PM
Posts: 8,850 Central Coast, Calif.
Snoopy
#67 bulb Current: 0.59 A Voltage: 13.5 V Power: 7.965 W LCL: 20.60 mm MOL: 36.56 mm Diameter: 19.0 mm MSCP: 4.00 MSCP Avg. Life: 5000 hours Filament: C-2R Bulb Shape: G-6 Generic Part No: 67 Base: BA15s
[Re: 19cuda73]
#2478045
04/05/18 09:30 PM
04/05/18 09:30 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
Here's another old thread on the ground wire with some info...Keep in mind if the wire was added by the dealership through a TSB then unless current owners had the vehicle from new then the SPDs really mean nothing other than speculation... ground wire thread IIRC the wire did have some script/part number on it. Since you can't pull the pics from the old formatt...Here's the 2 pics from the thread showing the referenced "survivor" it gives the info on the different sized terminals you asked about...
