Re: Trying to clean up my engine bay
[Re: Crock]
#885159
12/21/10 05:53 PM
12/21/10 05:53 PM
RapidRobert
You could take out the windshield wiper fluid spray assy and the horn if desired (it does come in handy & might be required (safety equip) in some states). You would need to go w an alternate coil that runs on full 12V to delete a 2 terminal ballast. Actually a GM HEI module mounted on a plate of alum under the dist does wonders for cleanup as you elim the big bulky ECU and the miniscule GM one (the HEI) is hidden under the dist
