Re: Fuel Gauge still not working, What the......
[Re: Chally426]
#88498
07/14/08 02:30 PM
07/14/08 02:30 PM
RapidRobert
if you pull the wire off the sending unit(w key on) does the gauge drop to E? & if you ground it(w key on) does the gauge read the same place(F) as in your description?
[Re: Chally426]
#88501
07/14/08 05:32 PM
07/14/08 05:32 PM
RapidRobert
I'm with Stumpy,take sending unit out & if float isn't waterlogged move it thru it's range of travel(hot wire hooked up AND the unit grounded & key on) & see how far off the gauge reads now.
[Re: 74-440Charger]
#88504
07/15/08 06:40 AM
07/15/08 06:40 AM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
A mopar will stay on E if it dosent have a ground.It goes dead full if the sender is shorted to ground.Thats why you test it by unhooking it and grounding the gauge wire.Sounds like the sender is shorted to ground.Rocky
Chrysler Firepower
