Some Dynamic CR calcs... 93-octane friendly? #884981
12/21/10 11:21 AM
12/21/10 11:21 AM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Do these Dynamic CR values really indicate how well the particular combinations would handle 93-octane fuel?
1. Assume closed-chamber heads w/ .040" quench.
2. Dynamic CR calcs using http://www.wallaceracing.com/dynamic-cr.php
3. Intake Closing calculations using SAE duration (.006” valve lift)
The street roller cam to be used in my 448 w/ 11.0 CR:
298/304 on 108 + 0 ==> Intake Closes at 77 ABDC ==> 7.78 DCR
298/304 on 108 + 2 ==> Intake Closes at 75 ABDC ==> 7.94 DCR
The solid flat-tappet cam used in my 452 w/ 10.8 CR:
302/302 on 108 + 2 ==> Intake Closes at 77 ABDC ==> 7.64 DCR
Re: Some Dynamic CR calcs... 93-octane friendly? [Re: BradH] #884982
12/21/10 11:42 AM
12/21/10 11:42 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
You know how I feel about this
I think static is overplayed to a point and dynamic is more what it's about!!! And you know I like to race on pump gas!! I'm no pro at all but real world experience don't count to some around here!
Mopar Performance
Re: Some Dynamic CR calcs... 93-octane friendly? [Re: BradH] #884983
12/21/10 11:47 AM
12/21/10 11:47 AM
Delray beach, Florida
P
Performance Only Offline
P
your in the 89 octane safe zone with those numbers.
machine shop owner and engine builder
Re: Some Dynamic CR calcs... 93-octane friendly? [Re: Performance Only] #884984
12/21/10 11:49 AM
12/21/10 11:49 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Dram do you agree 9.00 is about the limit for 93? Always enjoy your expertise around here!!!
Mopar Performance
Re: Some Dynamic CR calcs... 93-octane friendly? [Re: moparniac] #884985
12/21/10 12:15 PM
12/21/10 12:15 PM
P
P
i think it's a close approximation. there's other factors involved. rushed for time right now. i'll visit this one again later.
Re: Some Dynamic CR calcs... 93-octane friendly? [Re: BradH] #884986
12/21/10 12:25 PM
12/21/10 12:25 PM
Az
Crizila Offline
Crizila  Offline
Az
How do you know that using .006" for a closing event is correct? Many cam suppliers these days are using .050" for opening and closing events and don't give any numbers at .006". Don't think the calculator tells you what to use - or gives you a conversion?
Fastest 300
Re: Some Dynamic CR calcs... 93-octane friendly? [Re: Performance Only] #884987
12/21/10 12:25 PM
12/21/10 12:25 PM
BradH Offline OP
BradH  Offline OP
First, more details on the two cams:
COMP Xtreme Solid Street Roller
298/304 @ .015", 260/266 @ .050", .016" lash
COMP XX Solid Flat-tappet
298/@ .020", 266 @ .050", .020" lash
Re: the duration #s... SAE duration is measured as .006" valve lift after lash. You can figure out where on the cam lobe this maps to by then dividing that point by the rocker ratio.
Example: (.016" lash + .006" lift) / 1.5 = .0147" lobe lift. In this case, since COMP's Xtreme street rollers advertised durations are rated at .015" lobe lift, they're virtually the same as the SAE duration when using that lash value.
You need to use a realistic estimation of the seat-to-seat duration to determine where the valve is actually closing. The effects of lash and the various rates of acceleration from where lobes are rated for "advertised" duration vs. .050" #s cannot be ignored. I can think of two cams where the .050" are virtually the same, yet their .020" durations are quite different as are their lash specs:
- 302, 266, .608" (1.5), .026" lash
- 294, 267, .609" (1.5), 016" lash.
The SAE durations between the two cams are about 5 degrees different... and it's the 294 @ .020" cam w/ the .016" lash that's the larger of the two (305 vs 300). There's no way to "see" that difference from comparing only .050" values.
Re: Some Dynamic CR calcs... 93-octane friendly? [Re: moparniac] #884988
12/21/10 01:10 PM
12/21/10 01:10 PM
BradH Offline OP
BradH  Offline OP
From what I've been able to find discussed here and elsewhere (SpeedTalk.com, etc.), I think they they both need to be taken into account.
As the RPMs rise and the engine becomes more efficient, it's going to transition from operating under the lower DCR to conditions where the actual static CR takes over. The idea that you can use a big static CR w/ low(er) octane fuel and "crutch it" with a long duration cam only holds up to a certain point, at which time that big CR is still going to make itself known.
And if I knew those limits and points, I wouldn't be posting questions like this.
Re: Some Dynamic CR calcs... 93-octane friendly? [Re: BradH] #884989
12/21/10 02:06 PM
12/21/10 02:06 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I hope my HEMI grind cam helps out my new cause!!
Mopar Performance
Re: Some Dynamic CR calcs... 93-octane friendly? [Re: moparniac] #884990
12/21/10 02:32 PM
12/21/10 02:32 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I use the KB-Silvolite calculator for mine. That uses the intake closure at .050. My guess is just like advertising numbers for cams that removes some of the variables associated with the modern cam lobe shapes. I also think quench is critical and I set it this way: Bores over 4.10 I set quench at .035-.040. For smaller than that it's .030-.035. Knowing that...I use 8.75:1 dynamic with aluminum heads and a tight quench as a maximum for pump 93/10%ethanol as I get in the northeast. For iron closed chamber with good quench that drops to 8.5:1, and with open chambers I don't like to go over 8.25:1. I have not had any tuning/ping/detonation issues with pump 87/10% ethanol on any engine regardless of chamber or design using 8.25:1 as a max.
IMO, for what you have. It's low. But I build steet engines and if you're into revving well beyond 6K I think it's important to keep the dynamic figure down a little from my maxes. That's because it's my opinion that the dynamics of the whole intake/burn process change as rpms rise and the intake tract gets more efficient (pressure waves). I feel there will be more resulting pressure in a cylinder once the efficiency gets up past 90%. The compression ratio never changes. But the amount of intake charge occupying that space does go up. Just my opinion there tho.
Re: Some Dynamic CR calcs... 93-octane friendly? [Re: BradH] #884991
12/21/10 02:42 PM
12/21/10 02:42 PM
Az
Crizila Offline
Crizila  Offline
Az
100% - and I've got broken pistons to prove it . It's all about how much of a margin for error you want to leave on the table. I've heard some horrendous numbers (IMO) coming from this sight ( reads expert builder )that I wouldn't even consider for a build. One bit of info that cam Mfg'ers are giving out more often these days is suggested cranking Cyl press. Although my Dynamic CR ( best I can figure ) is 9.7:1, my cylinder cranking pressure is about 20psi above what my cam Mfg recommends for that cam, so I DO NOT run pump gas.
Fastest 300
Re: Some Dynamic CR calcs... 93-octane friendly? [Re: BradH] #884992
12/21/10 03:17 PM
12/21/10 03:17 PM
BradH Offline OP
BradH  Offline OP
You know what's really sad? That I can search Google for stuff like this thread and come up w/ another Moparts.com thread from only a couple of months ago that sounds "a lot" like this one.
Is it just me (or even because of me?), or is this place turning into a broken record?
Re: Some Dynamic CR calcs... 93-octane friendly? [Re: moper] #884993
12/21/10 03:24 PM
12/21/10 03:24 PM
BradH Offline OP
BradH  Offline OP
We've got the same shi... I mean stuff... here.
I'm hitting close to 7000 RPM in the traps already w/ the old combination. It'll probably pick up a couple hundred revs assuming I find some more power in the future.
Re: Some Dynamic CR calcs... 93-octane friendly? [Re: BradH] #884994
12/21/10 05:05 PM
12/21/10 05:05 PM
UK
602heavy Offline
602heavy  Offline
UK
...i guess guys will repeat themselves if they feel the info is correct , were you looking for something more than what was posted two months ago?...just saying not trying to be funny.
Intake valve closure is just part of the puzzle when considering which fuel to use , lots more variables.
Re: Some Dynamic CR calcs... 93-octane friendly? [Re: 602heavy] #884995
12/21/10 05:18 PM
12/21/10 05:18 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Thats why it is called Hot Rodding, sometimes you just don't know the answer till you try it. It is not an exact science. You just push it to the limit then back off a hair.
Getting old just means you were smarter than some and luckier than others.
Re: Some Dynamic CR calcs... 93-octane friendly? [Re: BradH] #884996
12/21/10 05:32 PM
12/21/10 05:32 PM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
I ran 11.8 static/ 9.11 dynamic with 210 cranking compression before. But that was with 93 octane no ethonal. Quench was .038. Was my old 511 with a comp extreme solid roller 248/254 @ 050.
Re: Some Dynamic CR calcs... 93-octane friendly? [Re: BradH] #884997
12/21/10 06:33 PM
12/21/10 06:33 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Challenger 4.150 stroke 248/254 @ 50
11.12 static --- 8.56:1 dynamic
Intake Valve Closes ABDC - 69
Dart 4.250 stroke 269/269 @ 50
11.0 static --- 9.07:1 dynamic
Intake Valve Closes ABDC - 60.5
both raced on pump fuel with no pinging or signs of detonation in either setups... however I have never caught air better than 2400DA and that was with the chally... those dynamic number are figured above are at altitude so crappy air the dynamic is lower yet and I would have started to watch the dart closer in "good cool air"!
you can see the dur @ 50 is a good bit higher on the dart "which higher duration bleeds of more cylinder pressures making pump gas friendly" but look at the timing events between the 2! the dynamic is "worse" on the dart and the timing event is much lower!
my new setup on the dart will have more static and less dynamic than previous setup! and oh yea! my cam will have higher Intake Valve Closing ABDC than before on the dart also... just sharing my data is all!
Mopar Performance
Re: Some Dynamic CR calcs... 93-octane friendly? [Re: BradH] #884998
12/21/10 07:04 PM
12/21/10 07:04 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Another member (toward the bottom of the page -- https://board.moparts.org/ubbthreads/show...=1&fpart=2) actually checked his combo first then input the combo into the Wallace calculator using the .050" number. The Wallace was accurate to less than 1 psi. So as far as that calculator goes it seems to be pretty accurate @.050" ICA.
Re: Some Dynamic CR calcs... 93-octane friendly? [Re: 64Post] #884999
12/21/10 07:37 PM
12/21/10 07:37 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
The only problem I have in using pressures as the indicator is a cylinder's pressure is dependant on the quality of parts, and machining, plus altitude, and those to me are hugely different from build to build when talking about different shops. I suppose it comes down to either empirical testing, or the "best guess" of a calculator...lol
Re: Some Dynamic CR calcs... 93-octane friendly? [Re: 64Post] #885000
12/21/10 09:02 PM
12/21/10 09:02 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
General question here: Which is it, Wallace calculator and 0.050" (lobe) or 0.006" (valve)? This will certainly give you different results.
