Used to be great set up when Manley made the mopar length/width 2.20 BBC journal rod. (14279 if I remember right). 440 source was making a similar spec rod but not sure they do anymore. now nearly all BBM stroker cranks are BBC journal length to take chevy width rods as well as journal size. Both those rods were .990 pin, not the 1.09 Mopar BTW. This rod was also very popular for the 470 inch 3.90 stroke low deck.
Nothing wrong with a 6.76/4.25 stroke, my last 508 RB was that way and it was (and still is with a new owner) a torquey high revving Mutha
Sluggo was DEFINATELY NOT a word anyone would use to describe it.
Six pack rod is not light but it's really no heavier than a lot of the aftermarket big block rods but it lacks the larger 7/16 bolts. If it's built right I wouldn't worry too much about it, as long as you're not putting 360cfm heads on it with a big cam where the torque peak is way up high it should be fine.
