wheel size 72 roadrunner/satellite #88457
07/14/08 12:50 PM
07/14/08 12:50 PM
Anonymous OP
Anonymous OP
Will 15 X 7 wheels fit/not rub/and look ok for front wheels on this car? If so, what size tire would you recommend?
Thanks,
Re: wheel size 72 roadrunner/satellite #88458
07/14/08 01:01 PM
07/14/08 01:01 PM
Upstate, NY
sixpack4spd Offline
sixpack4spd  Offline
Upstate, NY
That was a factory wheel size. Run a 245/60/15 or a 255/60/15 up front.
Re: wheel size 72 roadrunner/satellite [Re: sixpack4spd] #88459
07/14/08 01:17 PM
07/14/08 01:17 PM
Anonymous OP
Anonymous OP
Thanks. No problems rubbing?
Will 275/60 15's work on the back with 15 X 8 cop wheels?
Re: wheel size 72 roadrunner/satellite #88460
07/14/08 01:52 PM
07/14/08 01:52 PM
Upstate, NY
sixpack4spd Offline
sixpack4spd  Offline
Upstate, NY
As long as you run a reasonable offset. A factory 15x7 ralley wheel will not rub at all.
Same with the rear. A 275 will easily fit with the right offset.
Re: wheel size 72 roadrunner/satellite [Re: sixpack4spd] #88461
07/14/08 06:47 PM
07/14/08 06:47 PM
home of the Buckeyes
Butterscotch71 Offline
Lost Title
Lost Title
I have 255/60 15s with stock 15x7 rallye wheels on my 71 runner, and the fronts just slightly rub at full wheel lock....but just barely.
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
Re: wheel size 72 roadrunner/satellite [Re: Butterscotch71] #88462
07/14/08 06:56 PM
07/14/08 06:56 PM
Los Angeles, CA
Mobarge Offline
Mobarge  Offline
Los Angeles, CA
I'm running 275 60 15s on 15 X 10 steelies in the back, no problem.
'71 SSP - SOLD!
Re: wheel size 72 roadrunner/satellite [Re: Mobarge] #88463
07/14/08 09:07 PM
07/14/08 09:07 PM
NJ
SlimJim Offline
mopar addict
SlimJim  Offline
mopar addict
NJ
Me likey
