Re: which super stock spring to buy?
[Re: domingo]
#884440
12/20/10 04:49 PM
12/20/10 04:49 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Total car weight determines the spring choice. So if your car weighs in at 3600,get the 3600 rated spring.Same with trans,in your case you need the 4-speed springs.
[Re: greenpigs]
#884448
12/20/10 11:57 PM
12/20/10 11:57 PM
Posts: 2,177 ill
dennismopar73
ill
ok you will see alot of dif opinions on it yes they will run on the street BUT you will have to unadjust back them off to do it !! then go to track put load back in these are not easy as they will tell ive run both !! i will tell you buy the ss springs 3600 and you will be very happy not that impressed with them on drag car either they where designed for super stock racer (ford guy) that couldnt get the car to hook with a stock rear these meet ss rules as anyone on here will tell you even the standard leaf will work on a mopar without slappers and such are they ideal no but they will work! anyhow for the money diffrence , just my op alot will say diff you choose if its a race car put lader on it street car, either ss spring or good hd spring will work to
[Re: Thumperdart]
#884451
12/21/10 12:46 AM
12/21/10 12:46 AM
Posts: 2,177 ill
dennismopar73
ill
Unless you like the feel of a 2x4 stuck in the wheel well youre not going to like the ride but i really think the original poster will drive alot on street and little at track?? idonno tell you what just put a snubber under the car ,with it on the floor there is you ride feel
[Re: 8secDart]
#884453
12/21/10 01:54 AM
12/21/10 01:54 AM
Posts: 2,177 ill
dennismopar73
ill
mmm shocks im just stummified funny i can take the lower bar off, man does it ride good then put the bar back and might has well tie her down with a block no preload both bars lose i went all over this with the guys at caltracks this is a complete system from them monos bars shocks they just said that these are meant for racing not driving on street ,, but could be used very limited street use , not my words their words lucky it is in a race car,, but does see a little street stuff just what i know
[Re: bobdog106]
#884457
12/22/10 08:56 AM
12/22/10 08:56 AM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
You may want to try a lighter weight spring to keep the back end down. I have an E-body set that needed a 2" lowering block to sit level. I now have A Body springs and it sits level. 1.42 60 foot on Hoosiers.
I have had SS springs on my E-body's, and the newer ones are junk. They flaten right out, are uneven side to side, and arch the back on my up too far, by a bunch. Spend the money once and get split mono's and Caltrac's.. I run them on the street with zero gap, and they are perfect for the street. Actually a better ride than any SS springs I have ever had, and they sit level side to side...Not to mention, they are far lighter.
