Re: 71-74 Charger rear spring relocation
[Re: whitemtnelf]
#88440
07/14/08 05:24 PM
07/14/08 05:24 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Has anyone done the rear spring relocation on a '71-74 Charger or were you able to get wide rubber back there with out having to do it?
I had 13.5 X 29.5 hoosier quicktime pros on mine with inboard springs, half tubs, and 3.5 back spaced 10" Centerline wheel on my old Charger. In the old days, the biggest tire I could run was an L6015 with an 8" rim. The above Centerlines with an N5015 stuck out past the quarters by about an inch.
[Re: torkrules]
#88441
07/14/08 10:43 PM
07/14/08 10:43 PM
Posts: 5,275 near Harrisburg, Pa
440trk
near Harrisburg, Pa
Just out of curiosity, why did you move the springs inboard and do the 1/2 tubs, and only run 3.5" of backspace?!?!
I've got a 4.5" backspace 8" rim and 275/60/15's on the rear of my 71 R/T, and there is STILL room in the stock wheelwells.
I think you can get away with 5" of back spacing on the 71/4 Chargers, and not have any clearance problems...but you'll be close.
[Re: 440trk]
#88443
07/15/08 10:27 PM
07/15/08 10:27 PM
torkrules
I'm neurotic
I'm neurotic
I guess I should have mentioned that I narrowed the rear. I already had the rims so it was a question of making what I had fit properly. I suppose if the rear end was not narrowed, and you used a different offset wheel, it could work. You need to make sure you have enough clearance as the tires could rub when cornering
