Question about Mopar factory installed remote starters #88433
07/14/08 11:45 AM
07/14/08 11:45 AM
Detroit area
6PAX Online content OP
6PAX  Online Content OP
Detroit area
Does anyone know if a Mopar factory installed remote starter from a 2005 mini van would work on a 2004 Dakota? If so, are they hard to install?
Re: Question about Mopar factory installed remote starters [Re: 6PAX] #88434
07/14/08 01:38 PM
07/14/08 01:38 PM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
First of all...There is no such thing as a "factory installed" remote start on a 05 van
The remote start was a accessory bought over the counter and added on "dealer installed" if you will.
Assuming that it really is a MOPAR accessory piece and not some cluster that a dealer got aftermarket, the box is the same, simply swapping it to a 04 Dakota isn`t just a plug and play, The entire wiring harness is different as is the ignition switch configuration, If the unit has been installed, the SKIM key interface is a one time use (program) piece and cannot be used on another vehicle...So basicly you`ll need a complete install kit...or in simple terms...everything but the actual control box.
Rick
Blown71X V2.0 under construction 71 Cuda 383 4-SPD (maybe for sale) 2010 Challenger B5 Classic
Re: Question about Mopar factory installed remote starters [Re: Blown71X] #88435
07/14/08 05:06 PM
07/14/08 05:06 PM
Detroit area
Detroit area
Thanks for the info.
