Re: To Install Frame Connectors or Not in Cuda convertible?
[Re: DennisH ]
#884194
12/20/10 02:15 AM
12/20/10 02:15 AM
Posts: 2,592 None
71rm23
None
USCartool.
and possibly torque boxes
[Re: skh]
#884195
12/20/10 02:46 AM
12/20/10 02:46 AM
Posts: 903 Oregon
rtplumcrazy1
After reading your post i understand your dilemma. My friends faced the same problem with thier rag tops. One welded his frame connectors in-the other bolted them in. Both cars have since been sold. The Challenger was not an original car-and it did not matter to the new buyer-that the connectors were welded in. The road runner was an original car-and it did matter to the new buyer that the connectors wre only bolted in. Of the 5 potential road runner buyers/viewers-every one stated they would not have even considered the car-if the frame connectors were welded in. In your scenario i believe you would be happiest with bolt in pieces.
Put a big block 4 speed Scat Pack Dodge in your garage.
[Re: rtplumcrazy1]
#884196
12/20/10 09:42 AM
12/20/10 09:42 AM
Posts: 1,756 London, England
Gavin
London, England
All I can say is don't build your car for the next guy. Also, anything is reversible. Even a bolt-in means drilling holes, so will that be an issue to the next owner in itself? You can take out welded in frame connectors if it is an issue. In fact you could probably argue it would be easier to cut them out athan weld in the holes left by the bolt ins? Weld in are acknowledged to be much better than the bolt in - so if you are going to do it at all I'd use the weld in.
[Re: skh]
#884197
12/20/10 10:04 AM
12/20/10 10:04 AM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Does your car have any rust damage that you'll be repairing? Are you going to weld in those patch panels and such? Weld in sub-frame connectors enhance the structure of the car so dramatically, it's almost foolish not to put them in. They help reduce metal fatigue and potential chassis damage on the rest of the car.
I understand the purist's arguements, but weld in connectors can be removed if ever need be. All it takes is a little grinding and touch-up bodywork. You know, the kind of touch-up bodywork that you have to do when installing metal for rust repair.
In my book, unless it's a pristine survivor, by restoring it back to "stock", most people have modified it from original. Most guys over restore or restore incorrectly(myself included), so unless you do your restoration work like Dave from ECS or a big handful of other guys capable of true and acurate restorations. It's all gotta be redone to make it closer to a perfectly-stock, museum piece that doesn't or can't get driven anyway.
What's a little extra cutting, grinding and touch-up to remove welded in sub-frame connectors going to matter in the big picture.
There are quite a few upgrades that these old Mopars can benefit from that are easily swapped back to "stock". The performance and safety benefits for a car that will be used on the roads far outwieghs the work needed to return it to stock in preparation to be a museum piece or trailer queen.
This is the philosophy I use when I am "restoring" my cars. Perhaps, one day when I am too old and am rich enough to afford the true professional restorers, and I don't or can't drive my car anymore, I will have it professionally restored into a museum piece or total trailer queen that just sits locked in my garage between National Mopar Gold OE events. Until then, build it as accurately and true to original as you can, but choose modifications wisely that make it perform better in all kinds of ways, acceleration, stopping, comfort, control and looks without going too far beyond the bolt-on and in this case the small weld on modifications that really enhance the cars performance and safety without forever irrevocably altering it.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
