71 340 oil filter #884145
12/19/10 11:42 PM
12/19/10 11:42 PM
Shippensburg, PA
GardnersGotCudas Offline OP
Shippensburg, PA
i was wondering if o 71 340 should have a 90 degree oil fitting on the block i am using the log manifold thanks LIKE TO SEE SOME PICTURES
Re: 71 340 oil filter [Re: GardnersGotCudas] #884146
12/20/10 12:25 AM
12/20/10 12:25 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
it on a A body,
Re: 71 340 oil filter [Re: ademon] #884147
12/20/10 01:18 AM
12/20/10 01:18 AM
Shippensburg, PA
Shippensburg, PA
71 cuda 340 4 speed thanks
Re: 71 340 oil filter [Re: GardnersGotCudas] #884148
12/20/10 01:07 PM
12/20/10 01:07 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
I was told that only A bodies used the right angle filter for clearance issues and that everything else was the regular style
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: 71 340 oil filter [Re: mopars_1] #884149
12/20/10 03:46 PM
12/20/10 03:46 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I believe this is accurate for 1971 and later. I know 1970 E-bodies used the right angle filter apapter, but I don't think 1971 E-bodies did
