What Pad Compound ? #884101
12/19/10 09:27 PM
12/19/10 09:27 PM
Kokomo, IN
540dust Offline OP
540dust  Offline OP
Kokomo, IN
What brake pad compound are you mini-gn/dynalite caliper guys using ? I used to use the D but appears no longer available. Is BP10 Wilwood comparable ? What are you guys using ?
Re: What Pad Compound ? [Re: 540dust] #884102
12/20/10 09:06 AM
12/20/10 09:06 AM
pa
572charger Offline
572charger  Offline
pa
cant remember what wilwood told me to get as replacement have thebox somewhere !! call them to get the right pad i drive mine on the street, one pad i got from summit sucked on the street, they needed to be smokin hot before they stopped right [nobite ] get the right pad for your application
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
