Re: What's Your Fuel Cell Capacity?
[Re: 70Cuda383]
#883981
12/20/10 12:05 PM
12/20/10 12:05 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'll be building my tank for the Rampage... I use the stock sending unit but modifying it for the height of the tank(extending the float arm) that way it works with the stock gauge unit on the dash... in yours make sure it isnt touching the tank where its binding so it cant make the full travel... also check your ground
[Re: MR_P_BODY]
#883983
12/20/10 02:01 PM
12/20/10 02:01 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
mine is a tube sending unit, the foam float is inside the tube, magnet on the foam. as the foam rises and falls, the magnet changes the resistance through the sending unit.
the ground seems to work ok. sometimes the gauge reads full all the time, then it reads empty all the time, then it reads somewhere in the middle for awhile...almost as if the foam is stuck.
how do I fix this? my truck is a street truck, and I really prefer to have a functioning gauge instead of having to remember the miles and fill up per the number of miles driven.
**Photobucket sucks**
[Re: Dads426]
#883989
12/21/10 03:19 PM
12/21/10 03:19 PM
Posts: 6,236 san diego
JonsGottaDusta
san diego
Thanks for all the replies, everyone. I'm actually surprised to hear how many of you guy are running 3-5 gallon cells. Are any of you guys running EFI on your race cars with a cell? Thanks, - Jon D.
