Cam Question #883945
12/19/10 06:10 PM
12/19/10 06:10 PM
Wichita, KS
tmef Offline OP
tmef  Offline OP
Wichita, KS
This cam is for sale here on Moparts. I am in the early stages of planning my project. Single turbo, carb blow through, 8 to 10 psi max in a 91 Dakota. Would this be a decent cam?
http://www.summitracing.com/parts/DCC-4452782/
Re: Cam Question [Re: tmef] #883946
12/19/10 09:14 PM
12/19/10 09:14 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Should work, but with that much cam in a 318 it will be quite top-endy. Just be sure the turbo you choose will support the power and rpm you want.
