What engine bearings do you use?
#883804
12/19/10 02:19 PM
12/19/10 02:19 PM
Posts: 108 Wisconsin
MagnumExpress
Wisconsin
Just curious as to what brand and material do you use. What HP are you making and what is you're bearing life.
#9 in the world. 2006 IHRA Super Rod 2010 IHRA Div.5 Hot Rod Champion
Re: What engine bearings do you use?
[Re: MagnumExpress]
#883805
12/19/10 09:06 PM
12/19/10 09:06 PM
Posts: 43,174 Bend,OR USA
Cab_Burge
I have used most of the popular brands and style bearing for the last 40 yrs or so. I use to only use race Clevite tri metal CL77 rod nbearings and the appropriate main bearing part # in most of my cars, I would use the Clevite babbit bearings(and still do) in stick shift cars. Once Clevite got bought out by Michigan and others subsequent holding companys I ended up switiching to the Federal Mogul and Speed Pro tri metal race bearings, I do use there HD narrow full groove truck main bearings in all of my motors along with the appropriate part number, usually BB Chevy , race rod bearings for the rod sizes I'm using Lots of choices out there, make your choice
[Re: justinp61]
#883810
12/20/10 08:31 PM
12/20/10 08:31 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
Kings on the rods and Clevite full grove on the mains of my 408. I would've used Kings on the mains but they don't make them for the 360, only the 340 sized mains.
That's not true unless it's a recent development. I have king mains in my 408 and used clevites on the rods.
Unfortunately I dont think I still have the part number. I got them from Brian H.
[Re: MR_P_BODY]
#883816
12/20/10 11:58 PM
12/20/10 11:58 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
Clevite on almost every American engine I build Toyota and Honda get factory select fit stuff Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
