My '69 C500, replacement of the lower core support... #883494
12/18/10 11:30 PM
12/18/10 11:30 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang..
Well, as most of you know already, I have another C500... Well, I'm getting closer to getting her fired up, but wanted to take care of this beforehand. The lower core support was damaged during shipment, so I've undertaken the task of replacing it. I sold some misc. parts and bought the AMD core support section. Man, it's a nice piece. This is my VERY FIRST attempt at anything to do with body repair.
So, I wired wheeled the support to find the spot welds and then had at it with my grinder. Guess there's more efficient ways of doing this, but it was all the same cool to me. I was able to get the one side freed tonight. I'll mess with the other side soon. I know it looks rather crude. I also took some measurements before the original piece went bye-bye..
Troy
Houston Mopar Connection Club
Re: My '69 C500, replacement of the lower core support... [Re: hemi68charger] #883495
12/18/10 11:30 PM
12/18/10 11:30 PM
Houston, Tx
Houston, Tx
With the new AMD support on the ground..
Troy
Re: My '69 C500, replacement of the lower core support... [Re: hemi68charger] #883496
12/18/10 11:31 PM
12/18/10 11:31 PM
Houston, Tx
Houston, Tx
Taken some measurements before it's all off..
Troy
Re: My '69 C500, replacement of the lower core support... [Re: hemi68charger] #883497
12/18/10 11:45 PM
12/18/10 11:45 PM
Houston, Tx
Houston, Tx
Houston, we have separation....
Troy
Re: My '69 C500, replacement of the lower core support... [Re: hemi68charger] #883498
12/19/10 12:37 AM
12/19/10 12:37 AM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
You go AB!
Re: My '69 C500, replacement of the lower core support... [Re: FJ5_Fish] #883499
12/19/10 12:24 PM
12/19/10 12:24 PM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
Troy,The grinder is fine to grind the spot welds that you can reach with it. Only grind through the top layer,not both peices. Use a good sharp drill bit to drill the spot welds that you cannot get the grinder into. Only drill through the peice that you are removing. You can duplicate the spot welds,with plug welds. You will have to drill 1/4 inch holes in the new peice in the same spots as the original peice was spot welded. After you gring the welds,you can duplicate the spot welds by dressing them with a small amount of body filler. Before the body filler cures completely,use the eraser of a number two pencil and press it into the filler to recreate the look of the original spot welds. If you have access to a good spot welder,then you would not need to drill and plug weld the piece. It still ticks me off that the crossmember was damaged that day by the guy that supposedly does car shipping for a living,who doesn't know where to put the hook!
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: My '69 C500, replacement of the lower core support... [Re: chargervert] #883500
12/19/10 03:17 PM
12/19/10 03:17 PM
Houston, Tx
Houston, Tx
Hey Pete.
Thanks for the advice.. I made sure that any grinding didn't go beyond the support crossmember. On this one side, mission accomplished. I'll grind way the residual spot weld on the framerail and core support to make it smooth. I'll attempt the other side today, just got back from church.
Troy
Re: My '69 C500, replacement of the lower core support... [Re: hemi68charger] #883501
12/19/10 08:46 PM
12/19/10 08:46 PM
CrazyD Offline
CrazyD  Offline
Factory piece looks fairly straight in first picture, what was the damage?
Re: My '69 C500, replacement of the lower core support... [Re: CrazyD] #883502
12/19/10 08:50 PM
12/19/10 08:50 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
Bondo Spot welds...What will they think of next
CHECK OUT MY NEW WEB SITE !
Re: My '69 C500, replacement of the lower core support... [Re: anlauto] #883503
12/19/10 09:07 PM
12/19/10 09:07 PM
chargervert Offline
chargervert  Offline
Thats probably what is holding that barrel car together! One good bump,and it will come apart at the seems!
Re: My '69 C500, replacement of the lower core support... [Re: hemi68charger] #883504
12/19/10 10:07 PM
12/19/10 10:07 PM
anlauto Offline
anlauto  Offline
This coming from a guy who has a Charger with no roof
Re: My '69 C500, replacement of the lower core support... [Re: anlauto] #883505
12/20/10 01:07 AM
12/20/10 01:07 AM
chargervert Offline
chargervert  Offline
That was built a dozen years ago,and it's still in one peice!
Re: My '69 C500, replacement of the lower core support... [Re: chargervert] #883506
12/20/10 01:14 AM
12/20/10 01:14 AM
Houston, Tx
Houston, Tx
Finally got the complete unit out and spot welds ground down. Test fitted the new unit and it fits wonderfully. Now I'll wait for my friend to come over with the welder and he can teach me that... I was sort of proud of myself on this one. Felt good to have taken out the old piece and get the new one positioned.
Troy
Re: My '69 C500, replacement of the lower core support... [Re: hemi68charger] #883507
12/20/10 01:15 AM
12/20/10 01:15 AM
Houston, Tx
Houston, Tx
New piece positioned..
Troy
Re: My '69 C500, replacement of the lower core support... [Re: hemi68charger] #883508
12/20/10 01:15 AM
12/20/10 01:15 AM
Houston, Tx
Houston, Tx
Finally..
Troy
Re: My '69 C500, replacement of the lower core support... [Re: hemi68charger] #883509
12/20/10 01:18 AM
12/20/10 01:18 AM
chargervert Offline
chargervert  Offline
Looks good Troy! Looks like a nice fitting peice from AMD.
Re: My '69 C500, replacement of the lower core support... [Re: chargervert] #883510
12/20/10 10:07 AM
12/20/10 10:07 AM
Houston, Tx
Houston, Tx
Thanks Pete.. Now I see why everyone loves the AMD products.
I'm going to position the radiator in the car prior to tack-welding it in place, just to make sure clearances at the bottom aren't an issue.
Troy
Re: My '69 C500, replacement of the lower core support... [Re: hemi68charger] #883511
12/24/10 06:53 PM
12/24/10 06:53 PM
Houston, Tx
Houston, Tx
Did a little more today..
1. Drilled out some holes for the plug welding to simulate the spot welds.
Troy
Re: My '69 C500, replacement of the lower core support... [Re: hemi68charger] #883512
12/24/10 06:54 PM
12/24/10 06:54 PM
Houston, Tx
Houston, Tx
2. Passenger side positioned and held in place with some sheetmetal screws. I'll drill out the plug holes in the front later on..
Troy
Re: My '69 C500, replacement of the lower core support... [Re: hemi68charger] #883513
12/24/10 06:54 PM
12/24/10 06:54 PM
Houston, Tx
Houston, Tx
3. Driver's side positioned.
Troy
