Would these fit a MOPAR ? #883346
12/18/10 09:15 PM
12/18/10 09:15 PM
Georgetown Ontario Canada
anlauto Offline OP
anlauto  Offline OP
http://cgi.ebay.com/ebaymotors/Ford-Door...sQ5fAccessories
I know they're not 100% correct, but the price is a far cry from what they want for Mopar ones...Anybody ever use these ? Do they appear close ? Fit and function correctly ?
CHECK OUT MY NEW WEB SITE !
Re: Would these fit a MOPAR ? [Re: anlauto] #883347
12/18/10 09:56 PM
12/18/10 09:56 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Why don't you buy it and let us know.
Re: Would these fit a MOPAR ? [Re: FJ5_Fish] #883348
12/18/10 10:01 PM
12/18/10 10:01 PM
anlauto Offline OP
anlauto  Offline OP
I would like to, but I'm not in a position to spend the money to find out they're not even close.
Since quitting my day job I have to count every penny...
Re: Would these fit a MOPAR ? [Re: anlauto] #883349
12/18/10 10:17 PM
12/18/10 10:17 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
They will screw in but the sleeve is wrong.
Original is metal with rubber insert.
These are grey plastic with no rubber.
Now back to bed for me.
Jules
Re: Would these fit a MOPAR ? [Re: anlauto] #883350
12/18/10 10:55 PM
12/18/10 10:55 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Here is a start!
Re: Would these fit a MOPAR ? [Re: FJ5_Fish] #883351
12/19/10 12:30 AM
12/19/10 12:30 AM
anlauto Offline OP
anlauto  Offline OP
Thanks Jules...Take care
Re: Would these fit a MOPAR ? [Re: anlauto] #883352
12/20/10 04:16 PM
12/20/10 04:16 PM
USA
E
ECS Offline
David Walden
ECS  Offline
David Walden
E
USA
Hi Alan,
I bought one to see if some of the pieces are interchangeable. The NOS ones from Chrysler have a letter stamped in the flat area of the threaded shaft. The factory version did not have this feature. If these are the same size, you could swap the Chrysler parts (rubber, washer, metal sleeve) to make a version that looks like the factory Chrysler unit. I will let you how this works!
Re: Would these fit a MOPAR ? [Re: anlauto] #883353
12/20/10 07:01 PM
12/20/10 07:01 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
it's a dorman part . avail at any better auto parts store
I can get you the pt# if your feeling risky.
BTW, for some reason I was thinking these were taller and would not work in the mopar latches
Re: Would these fit a MOPAR ? [Re: gtx6970] #883354
12/20/10 07:14 PM
12/20/10 07:14 PM
anlauto Offline OP
anlauto  Offline OP
Bill do you have any Mopar ones ?
Re: Would these fit a MOPAR ? [Re: anlauto] #883355
12/20/10 10:43 PM
12/20/10 10:43 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
New ? no.
