Keisler TKO600, shifter location A vs B body? #883219
12/18/10 05:05 PM
12/18/10 05:05 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Does anybody know the difference in where the shift location is on a B body TKO600 vs an A body TKO600?
I curious since you have to modify the floor anyways, if my trans in my 69 RR will fit my Demon?
Re: Keisler TKO600, shifter location A vs B body? [Re: NV69B7RR] #883220
12/20/10 12:11 PM
12/20/10 12:11 PM
Tennessee
rj8806 Offline
rj8806  Offline
Tennessee
While I don't work there anymore, I did their tech for 5 years...
The B-body shift position is further forward than an A-body shifter location. Also, the A-body transmission has a "valley" machined into the tail housing just forward of the shifter location to account for the torsion bar cross member rib that runs through the tunnel. On an A-body car, that rib must be cut somewhat (along with the tunnel) in order to fit a TKO. On a b-body, that cut is not necessary.
Bottom line...it will not fit correctly as a B-body specific shifter location. Contact them and see if they will work something out with you. If you can get them the transmission, it wouldn't take them very long to re-machine it to work with an A-body.....
Richard
