3200lbs and 8 3/4 ??? #883125
12/18/10 03:48 PM
12/18/10 03:48 PM
nc
E
earthmover Offline OP
E
nc
just would like to know if my 83/4 will be okay for a while in my duster when i get my motor done for the duster...plan on 750hp with ladder bars on stock frame rails. right now the car has moser axles and will geta spool,back brace,set of good gears..also i plan to bring the weight down on the car as time and money comes..thanks mike
Re: 3200lbs and 8 3/4 ??? [Re: earthmover] #883126
12/18/10 03:59 PM
12/18/10 03:59 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
You will be fine if you footbrake. Check your gears every 50 runs. If you are using street gears, the ring gear will start chipping teeth off at 100-150 runs.
If you are using a trans brake, you better have pro gears.
Re: 3200lbs and 8 3/4 ??? [Re: cgall] #883127
12/18/10 04:05 PM
12/18/10 04:05 PM
nc
E
E
nc
no plan to run a t/b just foot thanks for the tips
Re: 3200lbs and 8 3/4 ??? [Re: earthmover] #883128
12/18/10 04:19 PM
12/18/10 04:19 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
MW caps would be good insurance.
Re: 3200lbs and 8 3/4 ??? [Re: earthmover] #883129
12/18/10 04:20 PM
12/18/10 04:20 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
I would install a billet cap.
Re: 3200lbs and 8 3/4 ??? [Re: Darryls-Demon] #883130
12/18/10 04:25 PM
12/18/10 04:25 PM
nc
E
E
nc
i forgot about those thanks guys..where can they be had at??
Re: 3200lbs and 8 3/4 ??? [Re: cgall] #883131
12/18/10 04:31 PM
12/18/10 04:31 PM
Western,Pa.
MagnumDartSport Offline
Western,Pa.
If I had to check my gears every 50 runs I wouldn't race!!!!
I'm at 3300 lbs with 1.46 60ft times.I do have MW billet caps with lightened/polished street gears and have to be close to a 1,000 runs over the last 8 yrs. IMHO you should me fine with that set-up.
Re: 3200lbs and 8 3/4 ??? [Re: MagnumDartSport] #883132
12/18/10 04:50 PM
12/18/10 04:50 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
He is talking 750 HP. He will find some weak links at that power level, stock blocks, street gears, 1/2" studs, stock 727 parts, etc.
Re: 3200lbs and 8 3/4 ??? [Re: cgall] #883133
12/18/10 05:07 PM
12/18/10 05:07 PM
Port Mcneill,B.C.Canada
I
Islandcuda Offline
Islandcuda  Offline
I
good luck, heres 610 horse at the motor , with 2800 pounds, Tim
67 cuda new best 1.395 60 10.240 at 128.58mph
Re: 3200lbs and 8 3/4 ??? [Re: Islandcuda] #883134
12/18/10 05:09 PM
12/18/10 05:09 PM
I
Islandcuda Offline
Islandcuda  Offline
I
another
Re: 3200lbs and 8 3/4 ??? [Re: Darryls-Demon] #883135
12/18/10 06:34 PM
12/18/10 06:34 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
i agree 8 3/4 are pretty damn good,just use mark williams caps and billet adjusters it'll be fine
Re: 3200lbs and 8 3/4 ??? [Re: fishy340] #883136
12/18/10 06:50 PM
12/18/10 06:50 PM
south central,Pa
mopar_to_ya Offline
mopar_to_ya  Offline
south central,Pa
here"s a pic of both my car and my Brothers car. both with an 8 3/4, and both low nines and 1.24-1.31 60ft times. You will be just fine with a your rear. But in my honest opinion, if you havent spent the money on axles and spool etc... yet. Why spend it twice. Sell your rear and put it in a dana, and never worry again.
It's a bigblock with a torque flight!!!
Re: 3200lbs and 8 3/4 ??? [Re: mopar_to_ya] #883137
12/18/10 06:51 PM
12/18/10 06:51 PM
south central,Pa
mopar_to_ya Offline
mopar_to_ya  Offline
south central,Pa
my Brothers car
Re: 3200lbs and 8 3/4 ??? [Re: mopar_to_ya] #883138
12/18/10 06:54 PM
12/18/10 06:54 PM
south central,Pa
mopar_to_ya Offline
mopar_to_ya  Offline
south central,Pa
by the way, both the above cars have 8 3/4 rears in them, with all good parts in them, with lots of runs on them.
Re: 3200lbs and 8 3/4 ??? [Re: mopar_to_ya] #883139
12/18/10 06:58 PM
12/18/10 06:58 PM
nc
E
E
nc
thanks guys for all the info so what year trucks do i need to be looking at for a dana.. i have (83/4) axels now which ive had for a few years in my small block combo...so ill like to do it 1 time and be done....since i have to do the backend anyway just a little more time and work lot or money....
Re: 3200lbs and 8 3/4 ??? [Re: earthmover] #883140
12/18/10 07:21 PM
12/18/10 07:21 PM
south central,Pa
mopar_to_ya Offline
mopar_to_ya  Offline
south central,Pa
You might be suprised what it will cost to put a dana in your car. If you have to buy a spool and gears and axles, and set-up cost. You are already well over a grand. Just sell your rear for a couple hundred bucks and then call dr diff or moser and ad 2 or 3 hundred and get a new one already set up and ready to go.
Or, for ex, I just picked up a 4.10 dana with a posi for 250 bucks, and go from there.
I can get them for that all day around here.
Re: 3200lbs and 8 3/4 ??? [Re: mopar_to_ya] #883141
12/18/10 07:24 PM
12/18/10 07:24 PM
nc
E
E
nc
thanks by the way i love those darts the green 1 is up there...any info on the combo youd share???
Re: 3200lbs and 8 3/4 ??? [Re: earthmover] #883142
12/18/10 07:29 PM
12/18/10 07:29 PM
south central,Pa
mopar_to_ya Offline
mopar_to_ya  Offline
south central,Pa
sure! The green car is my Brothers car. It is a small block. Both our cars are naturally aspirated too.
His motor is for sale on race parts right now if you want to see the combo!
We both have full int, stock wheel tubs, and cars are streetable, but not driven on the road,lol. Both have 727's and 8 3/4's.
Good luck with your car, sounds like it should run good.
Re: 3200lbs and 8 3/4 ??? [Re: mopar_to_ya] #883143
12/18/10 07:31 PM
12/18/10 07:31 PM
nc
E
E
nc
thanks man if it runs as good as your car ill be more then happy
Re: 3200lbs and 8 3/4 ??? [Re: earthmover] #883144
12/18/10 07:41 PM
12/18/10 07:41 PM
south central,Pa
mopar_to_ya Offline
mopar_to_ya  Offline
south central,Pa
Just be patient, and it will come. There is always little things that you can do to pick up a little at a tim.
Our Mom and Dad bought mine and my Brother's cars for us when we were 10 yrs old. So we have had them for quite awhile,lol. Been running these cars for a LONG time. Tinker here, and tweaking there, lol.
