Engine Doctors: Is this wound fatal for this 340? #88276
07/14/08 12:28 AM
07/14/08 12:28 AM
Central Ohio
rtidd440 Offline OP
super street
rtidd440  Offline OP
super street
Central Ohio
This motor snapped the #8 rod. The broken end took a chunk out of the bottom of the cylinder. I know that notching bores for clearance is done so could the rough edges be ground down? I hate to scrap it. I suppose it could be sleaved. I would appreciate any opinions. Thanks.
Rob 70 Swinger 340 4spd FC7 4 sale 69 Charger auto Q5 14 Challenger SRT8 Core 6spd black Deposit on Hellcat
Re: Engine Doctors: Is this wound fatal for this 340? [Re: rtidd440] #88277
07/14/08 12:50 AM
07/14/08 12:50 AM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Take it to a shop to check out for cracks.
Re: Engine Doctors: Is this wound fatal for this 340? [Re: rtidd440] #88278
07/14/08 12:51 AM
07/14/08 12:51 AM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
What looks like spider cracking higher in the cylinder bothers me more than the damage at the bottom...but like you said...worse case scenario, it can be sleeved.
2 Demons...no, not my kids!
Re: Engine Doctors: Is this wound fatal for this 340? [Re: 4speeds4me] #88279
07/14/08 12:57 AM
07/14/08 12:57 AM
Marine Corps Base Hawaii
DemonKyle Offline
USMC LCPL
DemonKyle  Offline
USMC LCPL
You can always put a band aid (sleeve) on it. Take it to a shop and have checked
Re: Engine Doctors: Is this wound fatal for this 340? [Re: DemonKyle] #88280
07/14/08 07:17 AM
07/14/08 07:17 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Why do you call a sleeve a band aide? A sleeve is a very good permanent repair. The aluminum engines come OEM sleeved as do a great many of the diesels.
Re: Engine Doctors: Is this wound fatal for this 340? [Re: MoparforLife] #88281
07/14/08 10:41 AM
07/14/08 10:41 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I've run a couple engines with all 8 sleeved (one to save a bored out Hemi and another to fix a 413 MW with lots of deep rust pitting in all 8) once properly installed they are likely better than before being sleeved.
Re: Engine Doctors: Is this wound fatal for this 340? [Re: ScottSmith_Harms] #88282
07/14/08 11:22 AM
07/14/08 11:22 AM
Re: Engine Doctors: Is this wound fatal for this 340? [Re: rtidd440] #88283
07/14/08 11:51 AM
07/14/08 11:51 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
The sleeves are fantasatic but you better have block checked to have a better idea if a crack may be present extending to water jacket, which the sleeve won't help.
Re: Engine Doctors: Is this wound fatal for this 340? [Re: rtidd440] #88284
07/14/08 12:42 PM
07/14/08 12:42 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Take the engine apart, smooth the broken edge with a die grinder and take it to your favorite machinist to check for cracks. Most likely it's OK.
