Lower Coil Spring Mount #882427
12/17/10 01:07 PM
12/17/10 01:07 PM
Pennsylvania
A0M397X Offline OP
A0M397X  Offline OP
Pennsylvania
I am looking for an adjustable lower coil spring mount to weld onto a rear axle housing. The attached picture shows something similar. I have looked at a few different racing catalogs/suppliers and they have a shock mount like this but I can't see any spring mounts. This is for a 2010 Challenger so I need a seperate mount for the shock and spring.
Thanks for any help!
No TV Party Tonight
Re: Lower Coil Spring Mount [Re: A0M397X] #882428
12/17/10 10:09 PM
12/17/10 10:09 PM
Bolingbrook, IL
HemiRunner Offline
super street
HemiRunner  Offline
super street
Bolingbrook, IL
Here is a set up from Art Morrison. See pic. It is actually for coil over type of set up, but you could use the lower portion just for a spring if you want to mount the shocks in a differnet location if that's what you're trying to do. It'd mount similar to what you have in your pic. of course, you'll need some sort of upper spring mt for it to fit into.
Blown & Injected, need I say more? 71 Road Runner 04 Dodge Ram 2500 4x4 CTD
Re: Lower Coil Spring Mount [Re: HemiRunner] #882429
12/17/10 11:08 PM
12/17/10 11:08 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
see Mike Roth. Mike has built 6 Drag Pac's and has quite a few custom pieces from headers, alternator brackets and afew other specifics for them.
mr2performance here
mr2performance@sbcglobal.net
home of the
Sox and Martin Hemi Duster
Re: Lower Coil Spring Mount [Re: HEMIFRED] #882430
12/17/10 11:21 PM
12/17/10 11:21 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
need more info. what diameter and length spring will you be using ?
home of the
