How much heavier will a hemi be? #882252
12/17/10 12:59 AM
12/17/10 12:59 AM
Phila Pa
scatpacktom Offline OP
Phila Pa
How much weight will a Hemi add over a 440 Six Pack?
Re: How much heavier will a hemi be? [Re: scatpacktom] #882253
12/17/10 01:05 AM
12/17/10 01:05 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Pretty darn close to 100#
Re: How much heavier will a hemi be? [Re: scatpacktom] #882254
12/17/10 12:17 PM
12/17/10 12:17 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
Tom,
It all depends upon what block and heads get used. MP Iron heads weigh more than a stock iron head, aftermarket block more than an original, etc. Mike is in the ballpark with his estimate.
Re: How much heavier will a hemi be? [Re: CRE2004] #882255
12/17/10 02:24 PM
12/17/10 02:24 PM
Phila Pa
Phila Pa
So 100 lbs for original castings then?
I know orig blocks are 260ish and MP are 290ish and the Mp heads are 20 lbs heavier than the orig at around 60.
100 lbs seems like alot but I guess I'll find out.
Thanks guys
