There are bigger Gen 3 HEMI's than a 392ci? #882244
12/16/10 11:42 PM
12/16/10 11:42 PM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
I was looking for a 6.1L HEMI and I found out there is a 7.0L and a 7.2L HEMI. I wonder what the power and reliability on those engines are like.
http://www.bouchillonperformance.com/G3HemiCrateEngines.asp
Re: There are bigger Gen 3 HEMI's than a 392ci? [Re: MuuMuu101] #882245
12/17/10 01:22 AM
12/17/10 01:22 AM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Just stroked 6.4's.. probably more to come. Now if they would just get rid of the coil on plug covers...
Re: There are bigger Gen 3 HEMI's than a 392ci? [Re: pishta] #882246
12/17/10 05:12 AM
12/17/10 05:12 AM
808CUDA Offline
808CUDA  Offline
Mopar just released an aluminum 3rd gen Hemi for $13,500
Re: There are bigger Gen 3 HEMI's than a 392ci? [Re: 808CUDA] #882247
12/17/10 01:11 PM
12/17/10 01:11 PM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
There are strokers based on the 6.1 in 392 (6.4L), 426 (7.0L), and 440 (7.2L) avail in the aftermarket already. Also a 392 stroker for a 5.7 based engine IIRC. Now a factory 6.4L as well in 2011 SRT8 vehicles, not to mention the Mopar Performance 6.4L crate engine that has been around for a few years. Lots of choices with the modern Hemi as far as displacement goes if you get away from stock.
Re: There are bigger Gen 3 HEMI's than a 392ci? [Re: Alikazam] #882248
12/17/10 07:55 PM
12/17/10 07:55 PM
Portland,OR
rjsjea Offline
rjsjea  Offline
Portland,OR
http://www.shophemi.com/c-459-61-hemi-to-440-stroker.aspx Check out Lxforums, they have a bunch of info on strokin a GenIII
Re: There are bigger Gen 3 HEMI's than a 392ci? [Re: rjsjea] #882249
12/17/10 08:36 PM
12/17/10 08:36 PM
SoCal
SoCal
Where and how much could I buy a 6.1L HEMI with everything I need (wiring harnesses, ecu, computers, etc.) to just drop it into my project?
Re: There are bigger Gen 3 HEMI's than a 392ci? [Re: MuuMuu101] #882250
12/17/10 09:02 PM
12/17/10 09:02 PM
IN
ahy Offline
ahy  Offline
IN
Check out Bouchillon Performance. They usually stock both the crate engine version and the OE setup. The crate engine is easier to "drop in". The OE version has more accessories but is setup for drive by wire.
Re: There are bigger Gen 3 HEMI's than a 392ci? [Re: ahy] #882251
12/17/10 10:09 PM
12/17/10 10:09 PM
SoCal
SoCal
They aren't that bad priced. $9k for a new engine and software to tune it yourself using a laptop.
http://www.bouchillonperformance.com/P5155067.asp
