Stock crank and rods with forged pistons... for...
#881811
12/16/10 03:52 PM
12/16/10 03:52 PM
Posts: 25 Lake St. Louis, Missouri
conv383
I have a 400 block with stock forged crank and rods from a 383 and i will be getting forged pistons (9 to 1 comp) Stealth alm heads. will it survive if i put on a paxton certifical SC on it with 5-6 boost? i would like to upgrade later with a new pulley to get 6-8 psi later. just want to make sure the stock parts will make a solid bottom end. thanks
Re: Stock crank and rods with forged pistons... for...
[Re: conv383]
#881812
12/16/10 05:17 PM
12/16/10 05:17 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
It should be fine. I run a stock bottom end on the TT440. It's got the cheapie Speed Pro forged pistons from Summit. The bottom end survived way too much detonation while I was learning to tune it with 8 psi. I ran 15 to 17 psi for a while and even surged it to 22 psi by accident. The detonation transferred metal from the piston crowns to the cylinder walls and blew the head gasket. There has never been a problem with the rods and crank. The bearings weren't hurt too bad either.
