Hey painters ,,how to spray metalic paint #881584
12/16/10 12:03 PM
12/16/10 12:03 PM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
In my job I have done a lot of painting ( boats ),but none of it metalic..I tried it and it sucked...it didn't even look metalic..I was told to spray with the gun on an angle,or less pressure etc..whats the trick ??
Re: Hey painters ,,how to spray metalic paint [Re: dynamite] #881585
12/16/10 12:26 PM
12/16/10 12:26 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I don't change the pressure...I spray a few coats using different patterns each time then the last coat gets misted on from a greater distance to even out the metalic particles...
Re: Hey painters ,,how to spray metalic paint [Re: dynamite] #881586
12/16/10 12:47 PM
12/16/10 12:47 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
you also need to ensure the metallic remains in suspension. Mix well before spraying and spray immediately. A few marbles in the pot (if using a siphon gun), and keep agitating. If using a gravity gun just mix well and spray.
Your base (color) coats should be pretty light, you want very little flowout because the metallic will start to separate from the paint and render a totally unacceptable look. Even rattle cans can show this 'effect'.
Re: Hey painters ,,how to spray metalic paint [Re: screamindriver] #881587
12/16/10 01:28 PM
12/16/10 01:28 PM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
Soooo ---what kind of pressure shuld I use with a gravity gun ????
Re: Hey painters ,,how to spray metalic paint [Re: dynamite] #881588
12/16/10 01:39 PM
12/16/10 01:39 PM
Assuming a Conventional gun (not HVLP) I would experiementing with 40-50psi
Re: Hey painters ,,how to spray metalic paint [Re: Pacnorthcuda] #881589
12/16/10 02:12 PM
12/16/10 02:12 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Isn't Gravity considered HVLP?
I run a Devilbiss FinishLine 3 (obsolete now) I am by no means a painter, but when I sprayed my car with PPG (I jambed three cars with Metallic paint)...I had 22psi at the gun. Having a regulator on the gun at the inlet is imperative...if you have it a regulator at the compressor you don't know for sure the loss you can incur because of the length on the air hose.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Hey painters ,,how to spray metalic paint [Re: Pyper70] #881590
12/16/10 02:20 PM
12/16/10 02:20 PM
No, gravity can be either HVLP or Conventional. Depends on tip/air-cap/needle design.
Re: Hey painters ,,how to spray metalic paint [Re: dynamite] #881591
12/16/10 02:21 PM
12/16/10 02:21 PM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
There are a lot of factors involved!! What paint/reducer/clear/hardener are you using? What gun are you using, is your compressor large enough??
I am a professional painter, I use a Satajet 2000 HVLP gun(German). 20Lbs at the gun and 10Lbs at the cap. Adjust the fan to about 10"s wide and stay at a distance about 10"s from the panel. Remember, 50% overlap on each pass. NEVER hold the gun at an angle! Never arch the gun to lt-rt! That is what we painters refer to as HEALING the gun. Keep the gun at 90 degrees to the panel at all times. Use the correct reducer/hardener for the ambient temp outside. You may want to go to youtube and look for some vids on how to apply automotive paint. Its hard to explain by typing!
Good luck!
Here is a shot of my truck I painted,
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: Hey painters ,,how to spray metalic paint [Re: CUUDAK] #881592
12/18/10 04:35 PM
12/18/10 04:35 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
What Cuudak said is spot on, also...........you still haven't mentioned if you are using single stage or base/clear? Two completely different animals........with single stage, you apply the paint (as suggested by Cuudak) being very consistant, then I usually dust a coat over the hood/trunk RIGHT after the last coat to even out the metallic. The sides too, depending on how they look. With base coat.........well, base coat is so easy you can almost apply it while watching TV, just dust the final color coats then check for mottling. If you have a gun that you are used to use it, if not get a more modern one. They shoot better. Just my
Re: Hey painters ,,how to spray metalic paint [Re: 4BBodies] #881593
12/18/10 05:05 PM
12/18/10 05:05 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
if you are spraying base coat you might want to be careful when you "DUST" the last coat. some base coats when they are sprayed on to dry the clear coat will fall off.
when spraying single stage make sure you "DUST" the paint over wet paint. if the paint being dusted is to dry will give you excessive orange peel.
perception is 90% of reality
Re: Hey painters ,,how to spray metalic paint [Re: dynamite] #881594
12/18/10 06:22 PM
12/18/10 06:22 PM
Jacksonville Florida
elitecustombody Offline
I own a shop and spray on regular basis,I like using slow reducer and very slow hardener when shooting any type of paint,metallic or solid color,base/clear or single stage.It allows a much better flow out and nice smooth finish,most paint nowadays have flop control additive ,it controls ther metallics helping to get them to be more stable without mottling and blotching.It's been a long time since I had metallic control issues,
when spraying metallics,first coat 50% overlap,25% on following coat(s) ,every coat must be sprayed in X in relation to previous coat,that means if you shot the hood in front to back strokes,next coat must be done in left to right,
