09 challenger pro charger problems #881490
12/16/10 02:59 AM
12/16/10 02:59 AM
Canada
Cape Offline OP
Cape  Offline OP
Canada
My buddy just pro charged his 09 challenger srt8 and put a blower cam in it to along with headers and 3" exhaust a different tune on it and a boosta pump. He went to a dyno shop tuned it and it has 580rwhp which is pretty good. His problem is when we went to the track the best he could get out of the car was 12.88@111mph it still has the stock suspension on it and tires to. He thinks it should be in the high 11s. Whats his problem. and its a 6 speed to. any help would be great. Thanks
Re: 09 challenger pro charger problems [Re: Cape] #881491
12/16/10 06:05 AM
12/16/10 06:05 AM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
Tires no question.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: 09 challenger pro charger problems [Re: topfueldart] #881492
12/16/10 01:08 PM
12/16/10 01:08 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
Did he upgrade the clutch as well whenm all this was done?
One day I will have something cool here.
Re: 09 challenger pro charger problems [Re: sdaurity] #881493
12/16/10 02:57 PM
12/16/10 02:57 PM
Canada
Cape Offline OP
Cape  Offline OP
Canada
Thanks. No its still the stock clutch he thinks its slipping and plans to upgrade this winter.
Re: 09 challenger pro charger problems [Re: Cape] #881494
12/16/10 02:59 PM
12/16/10 02:59 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
Not trying to be negative but if that car gets some sticky tires, that clutch would not stand a chance with that kind of power and 4000lbs.
Re: 09 challenger pro charger problems [Re: sdaurity] #881495
12/16/10 03:58 PM
12/16/10 03:58 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
Neither will the rear half shafts.
Re: 09 challenger pro charger problems [Re: Cape] #881496
12/16/10 04:16 PM
12/16/10 04:16 PM
Mr440GSS Offline
Mr440GSS  Offline
My buddy just pro charged his 09 challenger srt8 and put a blower cam in it to along with headers and 3" exhaust a different tune on it and a boosta pump. He went to a dyno shop tuned it and it has 580rwhp which is pretty good. His problem is when we went to the track the best he could get out of the car was [Email]12.88@111mph[/Email] it still has the stock suspension on it and tires to. He thinks it should be in the high 11s. Whats his problem. and its a 6 speed to. any help would be great. Thanks
Sorry to tell him, but they just don't run much quicker. The car is just too heavy. The 111 mph trap speed tells a lot. I could only run 112 mph with my Procharged Challenger.... Have since sold that car for a new "off-make" muscle car that is a bit easier to get to run....
Re: 09 challenger pro charger problems [Re: Mr440GSS] #881497
12/16/10 05:20 PM
12/16/10 05:20 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
They will run if you do it right. Yes they're heavy. The cars are no heavier than an E55 (automatic trans only) and those will trip 12.4 and 12.5 all day long in stock trim with a good launch.
The clutch needs to be upgraded and stickier tires will be needed. Get abusive and it will need half shafts too.
There are MUCH faster Challengers out there.
- Stu Harmon
Re: 09 challenger pro charger problems [Re: feets] #881498
12/16/10 06:57 PM
12/16/10 06:57 PM
Canada
Cape Offline OP
Cape  Offline OP
Canada
ya hes planning on drag radials and half shafts and urathane bushings to to stop the wheel hop. Ya his car is crazy heavy 4300lbs. Thanks for the help
Re: 09 challenger pro charger problems [Re: Cape] #881499
12/17/10 01:13 AM
12/17/10 01:13 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
my stock 08 srt8 runs 13.30's at 107 in drive with the TC on??
I would be looking at the clutch for that weak mile per hour. I did 2010 6 speed a few months back and it made 497 to the wheels @6lbs and was at the limit of fuel. 580 is real stout with just those couple of changes.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: 09 challenger pro charger problems [Re: Cape] #881500
12/17/10 10:57 AM
12/17/10 10:57 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Something is wrong somewhere for sure. It should be going way faster than that with 580rwhp. My Dakota was going pretty consistent mid-11s @ 120 mph or better at 580rwhp and that at 4200#. if the clutch was in fact slipping THAT much, it would be undriveable by now.
Re: 09 challenger pro charger problems [Re: Duner] #881501
12/17/10 03:35 PM
12/17/10 03:35 PM
Canada
Cape Offline OP
Cape  Offline OP
Canada
I dont know if anything is wrong with it but he cant keep the RPM up at all off the line because it just burns the tires off. It seems that the pro charger works from 3000 and up he cant keep it at that off the line. I think the 60 foots are 2.2 i think. I think with a new clutch tires and the other stuff he eas planned should make a huge difference. Thanks for the input.
Re: 09 challenger pro charger problems [Re: Cape] #881502
12/17/10 05:48 PM
12/17/10 05:48 PM
Davis, California, USA
MrBelvedere2 Offline
Sounds to me like he needs a Hop Not kit. Running that much power he needs it, it will wheel hop all over the place. Hop Not kit and sticky tires will do it. Mine puts 500rwhp and I need to get a hop not kit as the wheel hop is tremendous. check it out:
www.hopnot.net
1965 Plymouth Belvedere II hardtop
Re: 09 challenger pro charger problems [Re: MrBelvedere2] #881503
12/19/10 11:07 PM
12/19/10 11:07 PM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
The other serious question most people skip over is the driver mod. Can he drive the car? 95% of people in modern performance cars don't launch hard, and dont shift flat footed. My best buddies 04 Cobra run around a full second faster than most heavier modified cobras, because most people simply cant drive them well.
04 Cobra, Chip, Pulley, and Drag Radials. 11.78 @ 117, 1.65 60'
Re: 09 challenger pro charger problems [Re: Mr440GSS] #881504
12/26/10 01:11 AM
12/26/10 01:11 AM
808CUDA Offline
808CUDA  Offline
You gave up too soon. Lots of 4600 lb LX/LC cars running 10's and 9's and Procharger being the fastest of them all. I surely won't give up as easily as you did
Re: 09 challenger pro charger problems [Re: 808CUDA] #881505
12/26/10 01:55 AM
12/26/10 01:55 AM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
Sounds like you have a few problems. We have run 10.64 with a Kenne Bell and a few other mods on a street Challenger but had slicks and finally broke a 1000hp half shaft. Time ran out in the year before we could get in the 9's.
www.mrnormsgarage.com
JB Rhinehart, Realist
A-Body's RULE!
Re: 09 challenger pro charger problems [Re: 808CUDA] #881506
12/26/10 10:07 PM
12/26/10 10:07 PM
Mr440GSS Offline
Mr440GSS  Offline
Yeah, I probably did give up on the car too soon. I do think it had a bit more potential. The whiney Getrag rear diff and the notchy, grindy 2nd gear with the Tremec 6060 helped me make up my mind....
Re: 09 challenger pro charger problems [Re: Mr440GSS] #881507
01/02/11 08:17 PM
01/02/11 08:17 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
I have tuned this combo in the past and it should go mid 11's.
This car went 11.7 (11.8 in this post)on Nitto's with a crappy 60'
http://www.challengertalk.com/forums/f100/stock-block-5-7-magnacharger-11s-46355/
Not sure about the RWHP # you posted. Maybe that was that on a Dynojet dyno?
In any event I would be glad to take a look at the logs and tune file for this car (assuming it was tuned with a Diablosport product) and make suggestions/changes if you are interested.
Re: 09 challenger pro charger problems [Re: Cape] #881508
01/19/11 04:34 PM
01/19/11 04:34 PM
Airdrie, AB
Mills Offline
Mills  Offline
Airdrie, AB
Something is WAY off. 580 RWHP @ ~4600 lbs race weight to me means almost a 120 mph trap. I don't really care what the ET is...his trap is WAY off.
There are slightly modified SRT's running faster traps with simple bolt-ons with ~400 RWHP.
I hope he gets it figured out. FWIW...I've seen many Procharged SRT's running crappy traps. I've also seen some really haul. The 580 RWHP tells me it isn't the tune...which is typically the case.
1967 Satellite, CNC Eddy Headed 500ci Street Mauler
(Dyno'ed @ 600 HP / 650 ft-lbs)
2016 Challenger Hellcat - Holy Hell
2012 Hemi Ram Sport Crew Cab
2011 Avenger, Pentastar V-6
2007 SRT-8 Charger (Dyno'ed @ 470 RWHP)
1986 Caravelle, 318, aka "Rosco", Back Road Burner!
ALL Black...Bad Boys always wear Black!
