Re: back brace [Re: Scamp408] #881076
12/18/10 01:47 PM
12/18/10 01:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
any pics of the premade or homemade
This is mine... home made out of 2 X 3 X .125 wall
cant see it real well but it tappers out to the bearing
flanges
Re: back brace [Re: MR_P_BODY] #881077
12/18/10 02:32 PM
12/18/10 02:32 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
So everyone that is welding them without a jig are you leaving the rear complete? Or stripping it bare?
I see Tony leaves them complete, what does everyone else do.
If you're leaving them assembled I'm sure you're draining the gear lube, or that could cause problems
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: back brace [Re: DemonDust] #881078
12/18/10 02:34 PM
12/18/10 02:34 PM
Q
Quicktree Offline
Quicktree  Offline
Q
no full of gear lube, not enough heat to worry about anything if you do it right.
Re: back brace [Re: DemonDust] #881079
12/18/10 03:09 PM
12/18/10 03:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I narrowed mine and back braced it at the same time
so there wasnt any guts in it... you can do it with
the guts in it but like was said ... no fluid ...
I weld about a inch then move to the other side and
just jump all around to let it cool (no fixture but
I do have a shaft and collets for set up
Re: back brace [Re: Scamp408] #881080
12/18/10 06:15 PM
12/18/10 06:15 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Re: back brace [Re: DemonDust] #881081
12/18/10 06:19 PM
12/18/10 06:19 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Anyone have pics of how they jig up an 8 3/4?
Re: back brace [Re: jcc] #881082
12/18/10 07:18 PM
12/18/10 07:18 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Looks like a couple thousand dollar jig there...
I think I'll take my chances without one...
SDG Motorsports
Re: back brace [Re: DemonDust] #881083
12/19/10 11:04 AM
12/19/10 11:04 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
nice pics guys I am thinking about it
Re: back brace [Re: Scamp408] #881084
12/19/10 02:39 PM
12/19/10 02:39 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
The reason for a fixture is to pre-load the tubes away from the back braced side of the housing, being that when you weld, as the weld cools, it shrinks, hense warping. Here is a pic of the fixture I made when I back braced my Ford 9" Housing for my Road Runner. I have the housing bolted thru a plate, then have u-bolts at the ends of the tubes. I drew the tubes down about 3/16" each. I then Tig Welded the back brace, bouncing back-n-forth, side to side to control heat. When all done, the tubes came back darn near perfect. One side, right on, the other side within a 1/16". So, if I do another one, may only draw the tubes down about 1/8". After bracing was done, I cut the housing to the correct length & then welded new flanges on with my flange jig. DO NOT weld a back brace on, unless you plan to cut off & install new housing ends.
Re: back brace [Re: STEFF] #881085
12/19/10 03:19 PM
12/19/10 03:19 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
That jig would be very cheap to make. I like it
Why do you have to cut the ends off if you back brace it? If it doesn't warp I don't see a problem
SDG Motorsports
Re: back brace [Re: DemonDust] #881086
12/19/10 03:23 PM
12/19/10 03:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
He's changing the housing length
Re: back brace [Re: DemonDust] #881087
12/19/10 04:28 PM
12/19/10 04:28 PM
STEFF Offline
STEFF  Offline
For all the welding being done with a back brace, no if's about it. It's going to warp.
Re: back brace [Re: DemonDust] #881088
12/19/10 04:29 PM
12/19/10 04:29 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I set the housing in a cradle, chain each end, then use a bottle jack to bow the housing forward as I weld the back brace continuously.
My welding cradle looks similar to the big I-beam version posted earlier in the thread, only it has 1/2" thick forked uprights. I use a similar method to straighten bent housings.
Re: back brace [Re: MR_P_BODY] #881089
12/19/10 04:32 PM
12/19/10 04:32 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I don't know if I like that jig or not, whos to say the housing was straight to begin with? I would go with traditional jig imo.
Re: back brace [Re: Quicktree] #881090
12/19/10 07:33 PM
12/19/10 07:33 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Funny thing is I have a machine barstock to run through the housing and old center case but I dont have the bearing pucks.
Re: back brace [Re: STEFF] #881091
12/19/10 07:55 PM
12/19/10 07:55 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Don't ask me how i know
