CalTracs on the street #88101
07/13/08 06:25 PM
07/13/08 06:25 PM
Carson City, NV
babarracuda Offline OP
Carson City, NV
Do they make wheel bearing and gear noise more noticeable?
Re: CalTracs on the street [Re: babarracuda] #88102
07/14/08 10:13 AM
07/14/08 10:13 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I have run Cal-Tracs for many miles on the street, on my Duster and Dakota. They make the ride a little harsher, and you get a rattle from the linkage. (You should back off the preload on the street) You can use poly bushings in the spring eyes to take a small amount of the harshness away, and you can make nylon or rubber "bumpers" for the tops of the springs to quiet the rattles down too.
Re: CalTracs on the street [Re: slantzilla] #88103
07/14/08 12:49 PM
07/14/08 12:49 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I use heater hose on the preload bolt so that it doesn't rattle against the top of the spring.
Re: CalTracs on the street [Re: GomangoCuda] #88104
07/14/08 01:07 PM
07/14/08 01:07 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
been runnin mine on the street for years,4,129 lbs.yes it rattles a little and the ride is kinda stiff over bumps and railroad tracks but its a hot rod,all in all going down the road its not that bad.
Re: CalTracs on the street [Re: bonefish] #88105
07/14/08 04:38 PM
07/14/08 04:38 PM
Buenos Aires, ARGENTINA
madmax2 Offline
madmax2  Offline
Running you on the street with Caltrac's Mono-leaf?
'70 Dodge GTX sb 418ci (Early A-body),
Lunati Solid cam 270°/243°@.050/.548", Edelbrock Heads, Weiand X-CELerator,
Holley Terminator EFI, Tremec 6 sp manual, 3.90:1, TTI Headers.
Re: CalTracs on the street [Re: slantzilla] #2579084
11/16/18 11:58 AM
11/16/18 11:58 AM
NC
70charger512 Offline
#1 Thread Starter
#1 Thread Starter
NC
Man this is an old thread, but I didn't want to start a new one for this small of a question, is it bad to run 0 preload on the street?
Re: CalTracs on the street [Re: 70charger512] #2579142
11/16/18 01:48 PM
11/16/18 01:48 PM
GomangoCuda Offline
GomangoCuda  Offline
Bad in what way? Noise, ride, handling, traction? Are you using monoleafs, ss springs or stock springs? What shocks?
I have tried everywhere from 1/4" gap to 1 full turn preload with monoleaf springs. Now I just set the left at 0 and the right at 2 flats preload and call it done. I am going to guess that if you are more than 2 flats tighter or looser than this that you are lost and should be working on the shocks instead.
In my post above from TEN years ago I suggested heater hose to soften the noise. That worked but the hose wore out fairly quick. I now have a piece of 1/4"thick flat polyurethane glued to the top of the springs with 3M weatherstrip adhesive. It is holding up much better.
Re: CalTracs on the street [Re: babarracuda] #2579189
11/16/18 03:16 PM
11/16/18 03:16 PM
Locomotion Offline
Locomotion  Offline
Nick, check your PM's.
Re: CalTracs on the street [Re: GomangoCuda] #2579939
11/18/18 07:34 PM
11/18/18 07:34 PM
NC
#1 Thread Starter
#1 Thread Starter
NC
No, sorry, I just meant if it will negatively affect the Caltracs with no preload. I'm not worried about noise, and everything else should be normal with no preload correct? and I'm also most likely keeping the XHD springs, since Calvert said there wouldn't be any problems (although I will probably have to have a little more preload on one side, no biggie at all)
Re: CalTracs on the street [Re: babarracuda] #2580303
11/19/18 07:24 PM
11/19/18 07:24 PM
an8sec70cuda Offline
Nothing wrong running zero preload.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: CalTracs on the street [Re: babarracuda] #2580376
11/19/18 10:54 PM
11/19/18 10:54 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
they are nosier that stock and you will bounce around some.
Coming soon!!!!
