Re: 426 HEMI built from the ground up
[Re: MuuMuu101]
#880967
12/15/10 05:22 PM
12/15/10 05:22 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
[Re: MuuMuu101]
#880968
12/15/10 05:23 PM
12/15/10 05:23 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
So I found a HEMI block for sale and it has 2 small hairline cracks in the main webbing. The block is for $2800 and seems to look nice. I was wondering approximately how much would it cost to fix the block and have a machine shop build the rest of the engine. Thank you
A lot more than buying a new block , you can buy a new world block for about the same price as that used and abused unit , then you still have to spend money to fix the used and abused unit .
[Re: JohnRR]
#880969
12/15/10 05:34 PM
12/15/10 05:34 PM
Posts: 15,995 RI Deep in the rust belt
chargervert
There is a brand new world Hemi block for sale here on Moparts,in the Hemi engine for sale section for $2700.00. Save yourself a lot of grief and headace's that goes along with using a wounded block. It cost a lot to build a Hemi engine from scratch,and to have the block fail on you after spending a ton of money on machine work,would be a costly error. The only reason to fix a block like that would be if it was the matching numbers engine to an original Hemi car. I'd still be leary about stressing a repaired block. It would only be good for a show poodle.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
