LD340 mods #880803
12/15/10 01:04 PM
12/15/10 01:04 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
This is for a 400 hp 360, mostly street driven, had a torker II on then switched to a Holley strip dominator, the torker felt a bit stronger, the car is 95% street but has a 9.5" 4400rpm stall, this LD intake may go on a stroker in the future.
Re: LD340 mods [Re: ademon] #880804
12/15/10 02:04 PM
12/15/10 02:04 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
LD340 is great as is. Mine ran 11.40's on a 360 with nothing done to it.
Re: LD340 mods [Re: MoparforLife] #880805
12/15/10 02:30 PM
12/15/10 02:30 PM
NJ
JCCuda Offline
JCCuda  Offline
NJ
Look in the Mopar Perfomance Engine book (The Bible). The recommended mods. are shown in there.
I think it mostly refers to cutting down the center divider.
Re: LD340 mods [Re: JCCuda] #880806
12/15/10 03:11 PM
12/15/10 03:11 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
i was thinking of cutting the divider down, i was going to maybe gasket match a little but leave a little for a final match to the heads i use in the future.
Re: LD340 mods [Re: ademon] #880807
12/15/10 05:14 PM
12/15/10 05:14 PM
P
Paul_Fancsali Offline
P
Depending on the engine I have LD milled and LD not milled. Depend on conv or what you RPM you come out at as the milled will costa smidge down low
