Reproducing Factory Seaming Sealing #880450
12/15/10 01:21 AM
12/15/10 01:21 AM
Central Pa.
Cloned_Cuda Offline OP
Central Pa.
What brand to use and how to make it look like it was done by the factory.
Thanks!!!
Re: Reproducing Factory Seaming Sealing [Re: Cloned_Cuda] #880451
12/15/10 03:51 AM
12/15/10 03:51 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Which seam? I think on my car I used 4 different ones.
Fender to Inner Fender: SEM Expandable Foam
DRip Rail and others: Eastwoods has a beige colored caulk
Floor board seams - Used a thick roofing material from Home Depot
Trunk floor seams - Uses greay 3M seam sealer
Re: Reproducing Factory Seaming Sealing [Re: Cloned_Cuda] #880452
12/15/10 11:56 AM
12/15/10 11:56 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I generally use 3M brands in the cartiage/cauking gun style tube,..avoid the fast setting formulas as they shrink too much, depending on the "pattern" your trying to duplicate, use a brush or your finger to detail the seam to your liking,...the trick to avoiding it looking like a kid's fingerpainting is to have a open can of laquer thinner present so that you can dip the brush or your finger into it, as it aids in the flowout and smoothing of the seamsealer, experiment, and you'll soon find what works, and what dosen't
Mike
Re: Reproducing Factory Seaming Sealing [Re: DAYCLONA] #880453
12/15/10 11:32 PM
12/15/10 11:32 PM
Central Pa.
Central Pa.
Thanks!!!
