performer rpm, torker 2 or??
#880402
12/15/10 12:15 AM
12/15/10 12:15 AM
Posts: 3,696 jersey
Spaceman Spiff
jersey
On a 426 wedge with 10.5 compression, stealth heads and a cam with about 230ish duration and .550 lift. In a 4400 car with say a 3000 stall and 3.91's. Would a performer rpm or a single plane be preferred? 90% street car. Thanks.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: performer rpm, torker 2 or??
[Re: fourgearsavoy]
#880410
12/15/10 10:49 AM
12/15/10 10:49 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Performer RPM hands down is the best street/strip intake made IMHO Gus
Way best for what you have.
[Re: SG duster]
#880413
01/28/11 02:39 AM
01/28/11 02:39 AM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
4400 lbs of car? Need the high rise dual plane for sure (Performer RPM). Check hood clearance on it and DON'T overcarburate!! Good low end and plenty of midrange power!
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
[Re: Dodgem]
#880415
01/28/11 02:57 AM
01/28/11 02:57 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Waaay best for what you have, x 2
The TorkerII can work! , But its a RPM manifold, not a Torker vs The RPM being Both a Torker and A RPM manifold.
mike
