400-440 PISTON DIFFERENCES???
#880327
12/14/10 11:42 PM
12/14/10 11:42 PM
Posts: 475 HEMPSTEAD TX
CUUDAK
HEMPSTEAD TX
I have a question concerning the differences between a piston from a 400 B engine and a 440 BR engine..
I have been doin a bit of research and have noticed that the 400 piston at 4.34 is a bit larger than the 440 piston at 4.32.
My question, Is the pin location in the same spot between the two??
Do they make a .080 oversized for the 440?
I cannot believe that I can't find a .060 oversized forged piston for a 400 with the stock pin location and 9:1 compression that doesn't cost $800.00!!!
Trying to do a "Budget" build 400 with a 80mm B/W S480 turbo. First engine is a test to see what it will be able to endure..
HEEELP!!
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: 400-440 PISTON DIFFERENCES???
[Re: CUUDAK]
#880329
12/15/10 12:10 AM
12/15/10 12:10 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
HEEELP!!
That's because such a piston does not exist , especially in a forged unit, stock pin location on a 400 is more like 7.5/8.1 if you are lucky.
Contact member Performance Only , he's a WD for diamond , they'll MAKE you the piston you need .
[Re: CUUDAK]
#880336
12/15/10 03:48 PM
12/15/10 03:48 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Its at the machine shop now. I am sure he will do what is required.
Did you tell him to sonic check it? Cause if your gonna assume he'll check it.......................
[Re: 1_WILD_RT]
#880337
12/15/10 04:00 PM
12/15/10 04:00 PM
JohnRR
U.S.S.A.
Does this engine NEED to go out to .060 ?
There is no such thing as an .080 over 440 piston because the walls will be paper thin in spots at that overbore.
