Lokar kick down and throttle cable Questions??? #880182
12/14/10 09:20 PM
12/14/10 09:20 PM
indiana,usa
donsbelvedere Offline OP
indiana,usa
On the set up phase do you have the carb at full throttle then pull the kickdown cable forward {toward the front of the car}till it stops then lock it in?Thanks
Re: Lokar kick down and throttle cable Questions??? [Re: donsbelvedere] #880183
12/14/10 09:21 PM
12/14/10 09:21 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
To be honest, I'm not a fan of that Lokar kick down cable.
Re: Lokar kick down and throttle cable Questions??? [Re: donsbelvedere] #880184
12/14/10 09:25 PM
12/14/10 09:25 PM
florida
P
PJM Offline
PJM  Offline
P
florida
Yes. You have it correct.
Re: Lokar kick down and throttle cable Questions??? [Re: donsbelvedere] #880185
12/14/10 10:07 PM
12/14/10 10:07 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
But...the "kick down" lever does not have to be all the way back to work correctly, at least most of the way. It may take some tweaking to get it right.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
