mandrel for belt fuel pump #880056
12/14/10 06:07 PM
12/14/10 06:07 PM
England
fastfish451 Offline OP
England
what set ups are you guys running for methanol front mount belt pumps, i have a blp int bypass pump, would like to mount this on drivers side with small alt on pass side any idea on what mandrel i will need to fit ati damper. any pics of this would really help thanks
Re: mandrel for belt fuel pump [Re: fastfish451] #880057
12/14/10 09:24 PM
12/14/10 09:24 PM
Pound, Va
Chris Vanover Offline
Pound, Va
i use a mandrel from rons fuel. ronsfuel.com maybe? and use one of there brackets to mount my pump with.. mine is a BB rons sells bushing to go in the crank and uses a bb or sb chevy bolt and mandrel..hope this helps
Re: mandrel for belt fuel pump [Re: Chris Vanover] #880058
12/14/10 09:59 PM
12/14/10 09:59 PM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
I used to run a homemade one till I installed the moroso vacuum pump. I purchased it this fall from another member here (thanks poppaj) and it is also a moroso part. Nice piece as it bolted right to my ATI balancer. You can arrange the spacers as needed for pulley alignment. Beep
Re: mandrel for belt fuel pump [Re: Bigbeep] #880059
12/15/10 01:37 PM
12/15/10 01:37 PM
South Bend, Indiana
mistress Offline
mistress  Offline
South Bend, Indiana
use the mandrel from blp racing, part number 7021.4.000
it fits sb or bb and is the best you can buy. i am using rons 0 1/2 pump with there bb brackets. they can mount on either side and truly are plug and play. also you will need a fuel shut off if running in nhra and ihra events, mine is a barry grant cable operated .also i am using a barry grant bypass regulator to control pressure at idle and wot and sends fuel back to the tank. hope that help ya
Re: mandrel for belt fuel pump [Re: mistress] #880060
12/15/10 04:45 PM
12/15/10 04:45 PM
England
England
thanks for the info, what water pump are you running do you think the brackets will work with a meziere water pump
Re: mandrel for belt fuel pump [Re: fastfish451] #880061
12/15/10 05:14 PM
12/15/10 05:14 PM
South Bend, Indiana
mistress Offline
mistress  Offline
South Bend, Indiana
I am running a meizure water pump, the bracket kit from rons injection bolts to the timing cover and will miss the pump. just give them a call, they will have what you need. i know i am very pleased with rons and thats hard to do.
Re: mandrel for belt fuel pump [Re: mistress] #880062
12/15/10 09:55 PM
12/15/10 09:55 PM
NC
440Jim Offline
440Jim  Offline
NC
FWIW,
This is my Ron's setup (for injection) on my BB (low deck), passenger side and I have an alternator above it at the stock location.
The Ron's crank mandrel works fine, but the 1/2" bolt isn't the best for trying to rotate the crank by hand with a socket.
