68 Coronet Rt Project #879983
12/14/10 03:54 PM
12/14/10 03:54 PM
Poplar Bluff, Mo. 63901
2
268RTs4ME Offline OP
I have had this coronet for a few years now just starting on it. Previous owners butchered it it, air chisled out the wheel wells and trunk floor and messed up the quarters, however is a very solid factory 4 speed car, but will be alot of work, thinking about just putting a rear clip on it, I have and excellent parts car. any input or ideas are welcome..I have a 6 speed richmond tranny with long shifter I plan on installing in it, the original dana is still in it.
Re: 68 Coronet Rt Project [Re: 268RTs4ME] #879984
12/14/10 04:19 PM
12/14/10 04:19 PM
2
more pics
Re: 68 Coronet Rt Project [Re: 268RTs4ME] #879985
12/14/10 04:19 PM
12/14/10 04:19 PM
2
pics, see how they butchered up the quarters, and this car is as solid are a rock.
Re: 68 Coronet Rt Project [Re: 268RTs4ME] #879986
12/14/10 04:27 PM
12/14/10 04:27 PM
2
Another pic Floors and frame rails all good so is 4 speed hump, just a little surface which blasting will take car of.
Re: 68 Coronet Rt Project [Re: 268RTs4ME] #879987
12/14/10 04:28 PM
12/14/10 04:28 PM
2
picture, The hacked out wheel wells with air chisel
Re: 68 Coronet Rt Project [Re: 268RTs4ME] #879988
12/14/10 04:29 PM
12/14/10 04:29 PM
2
pic of parts car. Thinking about putting this rear clip on. any input?? Thanks Moparts
Re: 68 Coronet Rt Project [Re: 268RTs4ME] #879989
12/14/10 06:20 PM
12/14/10 06:20 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
personally, Id use that as a very last resort. it the rails are good in the car, Id just get AMD stuff thats readily available and fix what you got. I kind of dont like messing with the whole 'structure' of the car like that unless its nessisary. sweet looking coronet! 68 it one of my absolute favorite!
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: 68 Coronet Rt Project [Re: mopars_1] #879990
12/14/10 07:59 PM
12/14/10 07:59 PM
CANADA
Desmond Offline
Desmond  Offline
CANADA
Retain as much original structure as you can. That's what I had to do when I back-halfed my '70 Hemi GTX. Managed to save underseat area and rear quarter window inner side structure behind the jambs, some of the wheel well(s). Attached new metal to that...oh yeah, and a new roof
Re: 68 Coronet Rt Project [Re: Desmond] #879991
12/14/10 10:02 PM
12/14/10 10:02 PM
If that rear clip is as good as it looks I would use it that way you have factory sheetmetal and not repop metal.
Re: 68 Coronet Rt Project [Re: 268RTs4ME] #879992
02/25/11 11:07 PM
02/25/11 11:07 PM
Maryland
reno340 Offline
reno340  Offline
Maryland
If you clip the car, you will loose some valuable stamped numbers and will leave some tell tale signs that the car had the rear clip replaced and that would seriously effect the value of the car.
"There are only three real sports, Mountain climbing, Bull Fighting and Auto Racing. The rest are just games"
- Earnest Hemmingway
If you can't run with the big dogs, stay on the porch!!
https://www.youtube.com/watch?v=_xQJtN1_6DU
Re: 68 Coronet Rt Project [Re: reno340] #879993
02/26/11 01:48 AM
02/26/11 01:48 AM
Spokane Valley WA
dan6412 Offline
dan6412  Offline
Spokane Valley WA
I would spend the time and remove the 1/4s and wheel well from the back halfed one and put on the R/T. Myself, I am in the same boat you are I have a 68 4sp Bee and I just bought a nice 500 body to remove the 1/4s, wells and rear tail panel from, I dont have the money for AMD stuff and dont mind spending the time to move the sheet metal and it will take some time to take it apart right. My
Re: 68 Coronet Rt Project [Re: dan6412] #879994
02/28/11 10:07 PM
02/28/11 10:07 PM
London, Ontario
HotWheelz Offline
HotWheelz  Offline
London, Ontario
Color = RR1 ?
Re: 68 Coronet Rt Project [Re: HotWheelz] #879995
03/02/11 07:38 PM
03/02/11 07:38 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Another vote for not hacking the back off and using the donor clip. transfer what you need, no more.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
