1970 E-body - Disc brakes question #879971
12/14/10 03:29 PM
12/14/10 03:29 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Anyone have a picture of the dist valve with the holdoff valve installed on a 1970 E-body
I didn't take the original off, and would like to see how this mess goes together before it's goes in the chassis
valve in question shown
Re: 1970 E-body - Disc brakes question [Re: gtx6970] #879972
12/14/10 04:13 PM
12/14/10 04:13 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
I hope I can get this pix to post!! Hope this helps! Jeff
Re: 1970 E-body - Disc brakes question [Re: gtx6970] #879973
12/14/10 04:17 PM
12/14/10 04:17 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Re: 1970 E-body - Disc brakes question [Re: Challenger 1] #879974
12/14/10 04:37 PM
12/14/10 04:37 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Thanks fellas, That is exactly what I needed.
Now I just figured out the valve on hand does not have the plug in the one port
so off the parts house I go
Re: 1970 E-body - Disc brakes question [Re: gtx6970] #879975
12/14/10 06:44 PM
12/14/10 06:44 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Hi Bill,
I'm not sure if originality is a factor but I just wanted to throw this out there to you and make sure you have all the info you need to make an educated decision...Early 70 had a three piece system and late 70 had the one in your pic that basically combines that system into a 2 piece arrangement...
Re: 1970 E-body - Disc brakes question [Re: screamindriver] #879976
12/14/10 07:29 PM
12/14/10 07:29 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Thanks Colin,
I have the 2 piece style , SBD is about mid April 1970
Actually got it mounted this afternoon. now I'm just waiting on the booster to come back then maybe it'll have brakes
Thanks again
