Powering a winch #879707
12/14/10 10:44 AM
12/14/10 10:44 AM
Gilbert, AZ
Aspen7695 Offline OP
Gilbert, AZ
I just ordered a winch for my trailer. I am wondering if anyone has used a Jump Starter to power their winch. I only plan to use the winch occasionally(if the car breaks down). If you use one can you recomend a brand is good.
Thanks,
Raul
Re: Powering a winch [Re: Aspen7695] #879708
12/14/10 10:50 AM
12/14/10 10:50 AM
nc
E
earthmover Offline
earthmover  Offline
E
nc
ive got a buddy that use a jump box to work the winch works preety good since he doesnt have a place to store the batt.
Re: Powering a winch [Re: Aspen7695] #879709
12/14/10 11:02 AM
12/14/10 11:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks,
Raul
Your trailer has brakes on it right... so just use
a 7 pin plug with 1 pin power... that way when you're
plugged in you have power(wont have to worry if the
jumper box is charged)
Re: Powering a winch [Re: MR_P_BODY] #879710
12/14/10 11:22 AM
12/14/10 11:22 AM
NW PA
V10nacuda Offline
V10nacuda  Offline
NW PA
I had thought about that but figured that the winch would draw too much current for that wire so I ran seperate wires from the battery & used an electric forklift battery connector.
I had thought about putting a car battery on the trailer & use it for the break away & the winch. But was still unsure about current draw with the winch under load & that 12ga wire or less running through the factory harness.
Re: Powering a winch [Re: V10nacuda] #879711
12/14/10 11:37 AM
12/14/10 11:37 AM
MR_P_BODY Offline
MR_P_BODY  Offline
On my open trailer I have a hot wire going back but
the winch is small... never gave me any problems,
my big trailer I have a battery inside with the hot
line to it... I'm going to change the way I wired
it and go through a relay so when I shut off the key
it opens that circuit... I was having issue of a
draw in the trailer and it would kill my truck batteries
after a week or so if I left the trailer plugged in
but I found that the trailer battery had a short in it
Re: Powering a winch [Re: MR_P_BODY] #879712
12/14/10 11:45 AM
12/14/10 11:45 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Since you already bought the winch, look up the amp draw. Now check what the proper gauge wire is for that draw over 18-20 feet from the battery to the winch.
I've got a cheapie winch that has around 12 gauge wire on the snap in connectors. I use that and a set of jumper cables to reach the battery. I figure that the wire and connectors on the winch are the weak point, not the jumpers. Your winch may vary.
Re: Powering a winch [Re: RodStRace] #879713
12/14/10 12:14 PM
12/14/10 12:14 PM
GA
Boosted Offline
Boosted  Offline
GA
I guess I will ask why not put a battery in a box ont he trailer? I mafe a lockable box for the tounge of my trailer, mounted a battery in a battery box inside and ran a cable grom the battery on the truck to a quick connect at the trailer plug that connects the trailer battery.. Winch is hooked to the trailer battery and the truck charges the battery on the trailer for me. I have an 8000lb winch so I can drag all the junk cars I buy and shouldnt
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: Powering a winch [Re: Boosted] #879714
12/14/10 01:21 PM
12/14/10 01:21 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
For the winch on my trailer, I ran #2 cable from my Dually's battery to a quick-disconnect at the rear bumper, to which the winch connects, and I mounted a battery in a plastic marine box to power the winch if I'm towing behind my other truck or SUV.
The Dually charges the trailer battery while towing, but if the trailer sits for a length of time I just put a tender on its battery.
Trailer battery is Group 24, 800 CCA.
About 15 years so far with no problems.
