Re: Got my sub frame connectors today!! [Re: Moparnut426] #879532
12/14/10 11:40 PM
12/14/10 11:40 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I used 2x2 , similar weld set up. see if you can brace in the center some how or into the floor pan. Mine twisted and actually buckled the tunnel just behind the cross member. 4 speed cars like to crack the A pillers also.
Re: Got my sub frame connectors today!! [Re: rowin4] #879533
12/14/10 11:45 PM
12/14/10 11:45 PM
Finally a HUSKER again
Moparnut426 Offline OP
I thought about triangulating mine in the center some how. Might make 2 oval hoops out of heavy tubing, and go from there. I honestly dont see any issues. Its only a 10.8 to 1 408 with indybrocks, and a solid roller. I dont think Ill do too much damage. i dont ever run slicks, but I might try it.
Kasey
Re: Got my sub frame connectors today!! [Re: Moparnut426] #879534
12/14/10 11:45 PM
12/14/10 11:45 PM
Lehigh Acres, Florida
rickstershemi Offline
Nice job Kasey, I'm planning on doing similar....just a street fighter
Rickster
Re: Got my sub frame connectors today!! [Re: rickstershemi] #879535
12/14/10 11:48 PM
12/14/10 11:48 PM
Thanks Rick.
Only took me 2 and a half hours, and I had to keep re seting a breaker. The little Miller didnt like getting abused.
Kasey
Re: Got my sub frame connectors today!! [Re: Moparnut426] #879536
12/15/10 12:06 AM
12/15/10 12:06 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I agree with quicktree but there is no doubt you have stiffened the car up alot.
My chassis guy cut into the floor and put about 8" of connecter into the frame rails and welded them in.
68 Barracuda Formula S 340
Re: Got my sub frame connectors today!! [Re: Bad340fish] #879537
12/15/10 12:12 AM
12/15/10 12:12 AM
You guys who had a chassis guy build your stuff have a lot more engine im sure than I do. This thing is a STOCK suspension car so far, and the only real upgrade its gonna get is a set of caltracs and mono springs. Thats really the only reason Im doing anything to it. Because the majority of the time Im gonna be cruising, doing some launches, a few burn outs for the buddies, and thats it. Its really a way over done street car. Its on an 8" rim with 265 75 15s on it, and /6 torsion bars.
Kasey
Re: Got my sub frame connectors today!! [Re: Moparnut426] #879538
12/15/10 12:26 AM
12/15/10 12:26 AM
Indiana
W5Duster436 Offline
W5Duster436  Offline
Indiana
Exactly how mine were done. Can't tell in your pictures but mine were notched a bit towards the back so that I wouldn't have to cut the floor. I'll have to take a few pics.
'70 Duster - SDSS 436 W5 4spd (Gone)
'71 Dodge D100
'70 Dodge W100
Re: Got my sub frame connectors today!! [Re: W5Duster436] #879539
12/15/10 12:29 AM
12/15/10 12:29 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Looks great, Kasey! Like you said, A lot of the suggestions or comments you get here are well founded, but overkill for a stock suspension street car. I'm sure you've made a great improvement!
Re: Got my sub frame connectors today!! [Re: Moparnut426] #879540
12/15/10 12:31 AM
12/15/10 12:31 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
My stock suspension street car bent the drivers side door from a few years of street and track abuse.
Re: Got my sub frame connectors today!! [Re: W5Duster436] #879541
12/15/10 12:38 AM
12/15/10 12:38 AM
I lucked out and found some 1 1/2 x 2 1/2 rec tubing that is pretty heavy 3/16" stuff. I didnt have to notch anything, I bent a slight bend into them to fit the car better. I just installed a set on a 73 cuda that were over 250 bucks from Magnumforce, and I can say these are WAY heavier, and they fit a lot better, I sisnt have any 1/4" gaps to deal with.
Kasey
Re: Got my sub frame connectors today!! [Re: Moparnut426] #879542
12/15/10 12:40 AM
12/15/10 12:40 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Looks real good Kasey
Re: Got my sub frame connectors today!! [Re: Quicktree] #879543
12/15/10 12:54 AM
12/15/10 12:54 AM
New York
polyspheric Offline
polyspheric  Offline
New York
X2 - vertical height is much more important.
But - it's done, that's the bottom line.
If you actually get some wiggle, they can be improved considerably by patching an extra piece 1/2-way down the length on the bottom. A piece of 2-1/2" (to match your width) by 1" tall by 1/8" wall and 6" long is enough to help.
Boffin Emeritus
Re: Got my sub frame connectors today!! [Re: Moparnut426] #879544
12/15/10 01:21 AM
12/15/10 01:21 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I still might plate the rears a bit more, but I honestly dont know if its needed.
Looks good and should be strong enuff as is. Mine are done the same way and you can jack up the front of my car and the rear tire starts to exit the earth and the doors open and shut fine.
Re: Got my sub frame connectors today!! [Re: Thumperdart] #879545
12/16/10 12:38 AM
12/16/10 12:38 AM
I looked at it for a while today, and I think Im gonna make 2 reinforcements, the rear is getting a plate cut and made to cover the side back about 6" and break and cover the bottom also total about 10". The front is getting a 2 1/2" strap lapped over the weld seam on the very bottom and tords the front stub about 4" and only welded in 2" segments, and skipping 2" and so on.
No need to do a full weld on a cover plate.
Kasey
Re: Got my sub frame connectors today!! [Re: Moparnut426] #879546
12/16/10 03:10 AM
12/16/10 03:10 AM
rowin4 Offline
rowin4  Offline
I still think you should tie in the floor pan in midway. couple pieces of 1/8" x 2" or 3" coming off midway welded to the floor pan would really tighten it up.
Re: Got my sub frame connectors today!! [Re: rowin4] #879547
12/16/10 10:04 AM
12/16/10 10:04 AM
I honestly dont see how welding an 1/8" thick piece to some 14guage floor pan material thats flimsy is going to stiffen anything up. I can only see it tearing there if its 2 or 3" long. If I was going to tie it up to the floor pan, Id cut the rear section that floor pan level, and seam weld it inside the car. Ill have to do that when I have the interior out of the car when I redo the seats and headlinner.
Kasey
Re: Got my sub frame connectors today!! "updated DONE" [Re: Moparnut426] #879548
12/16/10 10:44 AM
12/16/10 10:44 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
very nice job Kasey... that should do the trick..
Re: Got my sub frame connectors today!! [Re: Moparnut426] #879549
12/16/10 01:19 PM
12/16/10 01:19 PM
owt west
Thread Ender1 Offline
owt west
Im gonna look over them good in the AM to see if there if there is anything I can improve on.
You can start by doing something with the battery cable and fuel line.
Re: Got my sub frame connectors today!! [Re: Thread Ender1] #879550
12/16/10 01:53 PM
12/16/10 01:53 PM
Battery cable is already fixed, I had to cut it so get it out of the hole it was ran through. And the Fuel line has been that way for a LONG time. Its -6 non colapsable braided black Russel line. I do need to move it through the frame rail, but thats it. Its tucked way away from everything.
If ya see an issue, point it out please.
kasey
