Got my sub frame connectors today!! "updated DONE" #879512
12/14/10 01:08 AM
12/14/10 01:08 AM
Finally a HUSKER again
Moparnut426 Offline OP
They costed me 18 bucks!!!
Here they are.
1.5x2.5x3/16" tubing.
Just a little cut here, and a plate there, and Ill be done.
KAsey
Re: Got my sub frame connectors today!! [Re: Moparnut426] #879513
12/14/10 01:10 AM
12/14/10 01:10 AM
Another. I have some 1/4" cold rolled plate to make the rest.
Re: Got my sub frame connectors today!! [Re: Moparnut426] #879514
12/14/10 01:41 PM
12/14/10 01:41 PM
Going to start fitting them inn today. Does anyone have any shots of how they tied theirs in? Im thinkint im going to make a couple plated that match the rear subframe rails, and just plate them inn. The front gonna be easier.
Kasey
Re: Got my sub frame connectors today!! [Re: Moparnut426] #879515
12/14/10 04:12 PM
12/14/10 04:12 PM
Boise
Moparteacher Offline
Boise
You should do a step by step with pics! That would be interesting and educational.
Re: Got my sub frame connectors today!! [Re: Moparteacher] #879516
12/14/10 11:08 PM
12/14/10 11:08 PM
Here is the process I took a LOT of pictures for ya.
Re: Got my sub frame connectors today!! [Re: Moparnut426] #879517
12/14/10 11:09 PM
12/14/10 11:09 PM
another
Re: Got my sub frame connectors today!! [Re: Moparnut426] #879518
12/14/10 11:10 PM
12/14/10 11:10 PM
and another
Re: Got my sub frame connectors today!! [Re: Moparnut426] #879519
12/14/10 11:12 PM
12/14/10 11:12 PM
the front plated welded to the subframe.
Re: Got my sub frame connectors today!! [Re: Moparnut426] #879520
12/14/10 11:13 PM
12/14/10 11:13 PM
angle cut starting to fit the rear stubbs.
Re: Got my sub frame connectors today!! [Re: Moparnut426] #879521
12/14/10 11:15 PM
12/14/10 11:15 PM
The fronts mocked up, and starting to tack in place.
Re: Got my sub frame connectors today!! [Re: Moparnut426] #879522
12/14/10 11:16 PM
12/14/10 11:16 PM
Starting to weld it inn.
Re: Got my sub frame connectors today!! [Re: Moparnut426] #879523
12/14/10 11:18 PM
12/14/10 11:18 PM
Some welds werent a grade A. but It is all 3/16 steel, and Im sure its a little over done so Im not too worried.
Re: Got my sub frame connectors today!! [Re: Moparnut426] #879524
12/14/10 11:19 PM
12/14/10 11:19 PM
I still might plate the rears a bit more, but I honestly dont know if its needed.
Re: Got my sub frame connectors today!! [Re: Moparnut426] #879525
12/14/10 11:21 PM
12/14/10 11:21 PM
I have it all inn and painted up, Im pretty happy W the results.
Re: Got my sub frame connectors today!! [Re: Moparnut426] #879526
12/14/10 11:23 PM
12/14/10 11:23 PM
This is where I might make a side plate for extra strength,
Re: Got my sub frame connectors today!! [Re: Moparnut426] #879527
12/14/10 11:26 PM
12/14/10 11:26 PM
Im gonna look over them good in the AM to see if there if there is anything I can improve on.
Re: Got my sub frame connectors today!! [Re: Moparnut426] #879528
12/14/10 11:26 PM
12/14/10 11:26 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I would have turned the long side vertical and incorporated them into the floor pan even though they look strong mounted horizonal they will flex
Re: Got my sub frame connectors today!! [Re: Moparnut426] #879529
12/14/10 11:27 PM
12/14/10 11:27 PM
Should keep the car from twisting Id hope.
Re: Got my sub frame connectors today!! [Re: Moparnut426] #879530
12/14/10 11:29 PM
12/14/10 11:29 PM
This car wont be hammered on at the track very much, If I drop into where Ill need a cage, Im not gonna go any farther with performance. The 408 will be a good street brawler.
Re: Got my sub frame connectors today!! [Re: Moparnut426] #879531
12/14/10 11:33 PM
12/14/10 11:33 PM
I dont know how much these will flex, I have a pressure guage on my press and it took 10 tons to get these to bend where I wanted them. I know structurally they would have been better cut into the floor pan, and set in length wise up and down, but this will be fine for now. My charger has some cheapo bold inn connectors, that have been welded inn, and they are way lighter than these. That car ran in the 8.50s. Im not worried.
KAsey
