yes it makes a nice torque monster for a work truck
I like to use the #302 heads that are closed chamber to up the CR even more than the 318 open heads
the small valves/runners do keep volosity up which helps bottom end for pulling
the holley street dominator intake is a real good intake for the street with the small ports/valves
not a high HP race engine but a very good work truck engine
I have done a few this way for work truck,done a few 318 with the 360 heads also
the 360 crank cut down to go in a 318 block along with the low CR pistons will pop them about +5 out the hole,thick gaskets and open 360 heads makes a nice 349 stroke...just not a high reving race combo,but will work in a work truck or 4x4 where torque is needed
in that big azz van..I would have done it a long time ago
