quickfuel 850 or aed 850 on a 418 stroker sm blk?? #879189
12/13/10 08:09 PM
12/13/10 08:09 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
im looking at buying a quickfuel 850 or aed 850.carb is currently a box stock holley 750 db pumper.motor is pump gas 9.7 comp 418 stroker small block , .600 lift solid roller cam,in a 88 dakota 3340#,727 with 4200 flash converter 3.91 gears and m/t drag radials.best et to date is 7.31@94 with no tuning last oct.thanks mike
Re: quickfuel 850 or aed 850 on a 418 stroker sm blk?? [Re: hp340nos] #879190
12/13/10 08:31 PM
12/13/10 08:31 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
between the two i would pick the AED
the AED is HO $680
the QF is Q series $680 race or $810 pro 850
is this for race only
WAXER
Re: quickfuel 850 or aed 850 on a 418 stroker sm blk?? [Re: QWK_ENUF] #879191
12/13/10 09:15 PM
12/13/10 09:15 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
its street/strip i drive about 40 minutes to the track one way.i go to track cpl times a month.
Re: quickfuel 850 or aed 850 on a 418 stroker sm blk?? [Re: hp340nos] #879192
12/14/10 02:52 PM
12/14/10 02:52 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
i would put a 950 on before i would an 850 on a piece like you have
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: quickfuel 850 or aed 850 on a 418 stroker sm blk?? [Re: hp340nos] #879193
12/14/10 03:01 PM
12/14/10 03:01 PM
Ma
Voluster Offline
Voluster  Offline
Ma
I ended up with a 950 on my 416
I bought a pro systems
Re: quickfuel 850 or aed 850 on a 418 stroker sm blk?? [Re: hp340nos] #879194
12/14/10 04:10 PM
12/14/10 04:10 PM
Northeast Georgia
47hudson Offline
47hudson  Offline
Northeast Georgia
We bought an AED850 several years ago and it has been on several of our engines as well as a few friends. It is without a doubt the best carb I have ever owned. starts and idles better than any other carb we have. I took off my Dominator and put it on my 496 to slow down a couple 10ths and the car would still run 6.30s and drive like a street car!
Re: quickfuel 850 or aed 850 on a 418 stroker sm blk?? [Re: 47hudson] #879195
12/14/10 04:22 PM
12/14/10 04:22 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
AED is by far one of the best carbs out there, i've met several guys useing them over the years & they love em, i'v never heard 1 complaint.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: quickfuel 850 or aed 850 on a 418 stroker sm blk?? [Re: joedust451] #879196
12/14/10 07:10 PM
12/14/10 07:10 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
why a 950 carb over an 850?thanks mike
Re: quickfuel 850 or aed 850 on a 418 stroker sm blk?? [Re: hp340nos] #879197
12/14/10 07:11 PM
12/14/10 07:11 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
850 actually flows more
WAXER
Re: quickfuel 850 or aed 850 on a 418 stroker sm blk?? [Re: QWK_ENUF] #879198
12/14/10 07:17 PM
12/14/10 07:17 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Are you sure about that???
Re: quickfuel 850 or aed 850 on a 418 stroker sm blk?? [Re: sshemi] #879199
12/14/10 07:21 PM
12/14/10 07:21 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
WAXER
Re: quickfuel 850 or aed 850 on a 418 stroker sm blk?? [Re: hp340nos] #879200
12/14/10 07:21 PM
12/14/10 07:21 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
a 950 generally moves air easier/ more air speed/velocity than an 850, and is better suited to a smallblock.Most anybody you talk to will say a standard 950 has better street manners than a standard 850 does.
I cant say as i personally know of a single guy who runs an 850 around these parts on any smallblock i am aware of.
Lots of 750, 950 and dominators, but no 850's i am aware of.
A few years back Patrick at pro systems gave me three carbs to test on my old w5 stroker motor. A 750, a 1000hp, and a dominator.The 1000 i believe was 950 based.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: quickfuel 850 or aed 850 on a 418 stroker sm blk?? [Re: B3422W5] #879201
12/14/10 07:30 PM
12/14/10 07:30 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
isn't the 950 a 850/750 mix. some one on moparts posted once it flowed less
WAXER
Re: quickfuel 850 or aed 850 on a 418 stroker sm blk?? [Re: QWK_ENUF] #879202
12/14/10 07:34 PM
12/14/10 07:34 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
I say a BIGS PERFORMANCE carb!!!!!
Re: quickfuel 850 or aed 850 on a 418 stroker sm blk?? [Re: MIKES_DUSTER] #879203
12/14/10 08:24 PM
12/14/10 08:24 PM
Az
Crizila Offline
Crizila  Offline
Az
I went with a Pro Systems 850 on my 408. Only run with it one time so far, but it seems to be right on the money out of the box. Their tech / info form is pretty thorough ( 2 pages I believe )and James asks the right questions.
Fastest 300
Re: quickfuel 850 or aed 850 on a 418 stroker sm blk?? [Re: Crizila] #879204
12/14/10 08:30 PM
12/14/10 08:30 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I run a QF 950 on my 416 it is a great carb 0 problems but I would love to try a 1050 dominator.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: quickfuel 850 or aed 850 on a 418 stroker sm blk?? [Re: QWK_ENUF] #879205
12/14/10 08:43 PM
12/14/10 08:43 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
The Holley branded 950 is,but the main body is modified to fit the throttle bores.The main venturi on the QF 950 is larger than the one from Holley,not sure about other brands.
Re: quickfuel 850 or aed 850 on a 418 stroker sm blk?? [Re: Dunnuck Racing] #879206
12/14/10 10:19 PM
12/14/10 10:19 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
so the 950 will have better street manners,truck is street/strip.not a daily driver just a toy.what will produce more power for better et at track with my combo?thanks
Re: quickfuel 850 or aed 850 on a 418 stroker sm blk?? [Re: hp340nos] #879207
12/14/10 10:32 PM
12/14/10 10:32 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
A Holley 950hp flows about 860 cfm and will have much better street manners due to the smaller venturi size. A really good signal to the booster and fuel curve is much better than most any 850.
Re: quickfuel 850 or aed 850 on a 418 stroker sm blk?? [Re: RobX4406] #879208
12/15/10 02:33 AM
12/15/10 02:33 AM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
I have ran both, the 850 ran faster on my old 416 then the 950 did. The 950 had better throttle responce with the smaller venturies but didnt do well with ET(over a tenth) compaired to the 850.
