quickfuel 850 or aed 850 on a 418 stroker sm blk??
#879189
12/13/10 08:09 PM
12/13/10 08:09 PM
Posts: 1,365 elmira ny
hp340nos
elmira ny
im looking at buying a quickfuel 850 or aed 850.carb is currently a box stock holley 750 db pumper.motor is pump gas 9.7 comp 418 stroker small block , .600 lift solid roller cam,in a 88 dakota 3340#,727 with 4200 flash converter 3.91 gears and m/t drag radials.best et to date is 7.31@94 with no tuning last oct.thanks mike
Re: quickfuel 850 or aed 850 on a 418 stroker sm blk??
[Re: hp340nos]
#879190
12/13/10 08:31 PM
12/13/10 08:31 PM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
between the two i would pick the AED
the AED is HO $680
the QF is Q series $680 race or $810 pro 850
is this for race only
WAXER
[Re: 47hudson]
#879195
12/14/10 04:22 PM
12/14/10 04:22 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
We bought an AED850 several years ago and it has been on several of our engines as well as a few friends. It is without a doubt the best carb I have ever owned. starts and idles better than any other carb we have. I took off my Dominator and put it on my 496 to slow down a couple 10ths and the car would still run 6.30s and drive like a street car!
AED is by far one of the best carbs out there, i've met several guys useing them over the years & they love em, i'v never heard 1 complaint.
[Re: QWK_ENUF]
#879198
12/14/10 07:17 PM
12/14/10 07:17 PM
Posts: 2,128 sweden
sshemi
sweden
850 actually flows more
Are you sure about that???
[Re: hp340nos]
#879200
12/14/10 07:21 PM
12/14/10 07:21 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
why a 950 carb over an 850?thanks mike
a 950 generally moves air easier/ more air speed/velocity than an 850, and is better suited to a smallblock.Most anybody you talk to will say a standard 950 has better street manners than a standard 850 does.
I cant say as i personally know of a single guy who runs an 850 around these parts on any smallblock i am aware of.
Lots of 750, 950 and dominators, but no 850's i am aware of.
A few years back Patrick at pro systems gave me three carbs to test on my old w5 stroker motor. A 750, a 1000hp, and a dominator.The 1000 i believe was 950 based.
[Re: MIKES_DUSTER]
#879203
12/14/10 08:24 PM
12/14/10 08:24 PM
Posts: 7,506 Az
Crizila
Az
I went with a Pro Systems 850 on my 408. Only run with it one time so far, but it seems to be right on the money out of the box. Their tech / info form is pretty thorough ( 2 pages I believe )and James asks the right questions.
Fastest 300
[Re: Crizila]
#879204
12/14/10 08:30 PM
12/14/10 08:30 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I run a QF 950 on my 416 it is a great carb 0 problems but I would love to try a 1050 dominator.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: QWK_ENUF]
#879205
12/14/10 08:43 PM
12/14/10 08:43 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
isn't the 950 a 850/750 mix. some one on moparts posted once it flowed less
The Holley branded 950 is,but the main body is modified to fit the throttle bores.The main venturi on the QF 950 is larger than the one from Holley,not sure about other brands.
