Switching from Power to Manual Steering - 70 Challenger #878987
12/13/10 03:40 PM
12/13/10 03:40 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Other than the gearbox, what's needed on the steering column? Is there a lenght difference?
thanks
Re: Switching from Power to Manual Steering - 70 Challenger [Re: varunner] #878988
12/13/10 03:55 PM
12/13/10 03:55 PM
In the twisties
RokketRide Offline
super gas
RokketRide  Offline
super gas
In the twisties
Yep, the manual box is much shorter.
Re: Switching from Power to Manual Steering - 70 Challenger [Re: RokketRide] #878989
12/13/10 04:03 PM
12/13/10 04:03 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
That's the adapter you need to use the shorter PS column with the MS box. You can find them on Ebay and from a number of Mopar & aftermarket suppliers. Best price is normally around $75 but I've bought them as cheaply as $55.
Re: Switching from Power to Manual Steering - 70 Challenger [Re: topside] #878990
12/13/10 04:13 PM
12/13/10 04:13 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Thanks. I may place an ad here to see if anyone wants to swap the whole PS column/gearbox set for a manual set. I see the re-built gearboxes are pricy: $300-400. It's probably cheaper to get a $50 used core and re-build it. I'm going racing and want a "firm feel" at the top end.
Re: Switching from Power to Manual Steering - 70 Challenger [Re: varunner] #878991
12/14/10 11:24 AM
12/14/10 11:24 AM
Northern Virginia
Moparmaniacc Offline
Northern Virginia
I'd swap you if I had time to pull my manual setup...I'm tired of wrestling the wheel driving around town. That plus the steering is so SLOW...I look like I'm driving a school bus whipping that wheel around...
