Wilson Intake spacer #878949
12/13/10 02:16 PM
12/13/10 02:16 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Posting for a friend. He has a 500 low deck wedge, 440-1 heads, 1050 Dom, 670 roller cam, 4800 stall, 4.56's in a 72 3200lb Demon. He'd like to know Good? Bad? Worth the $$$?
Thanks.
Coming soon!!!!
Re: Wilson Intake spacer [Re: Mr.Yuck] #878950
12/13/10 02:25 PM
12/13/10 02:25 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Sorry, I can;t help with the Wilson spacer as I have never used it.
We did put an APD Black Widow carb spacer on my motor when it was on the dyno and it did make some impressive gains.
I have yet to do an actual on track back to back test with an with out yet though.
Re: Wilson Intake spacer [Re: Mr.Yuck] #878951
12/13/10 02:37 PM
12/13/10 02:37 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I should add the car went 9:63@140 w/ bad 60 foot (cold track)
Re: Wilson Intake spacer [Re: Mr.Yuck] #878952
12/13/10 02:38 PM
12/13/10 02:38 PM
Az
Crizila Offline
Crizila  Offline
Az
I run one (a 4 holer) on my 408 - along with a single plane Victor 340. All I can tell you is that it didn't make anything worse. 60 foot times may have improved slightly, but really too small to say with confidence that it was an improvement.
Fastest 300
Re: Wilson Intake spacer [Re: WILD BILL] #878953
12/13/10 02:40 PM
12/13/10 02:40 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
They do make horsepower and torque. See this article (it's not Mopar but should be the same).
http://www.highperformancepontiac.com/te...ng_numbers.html
Re: Wilson Intake spacer [Re: Mr.Yuck] #878954
12/13/10 03:47 PM
12/13/10 03:47 PM
I have tested the Wilson dominator reversion spacer on a 700 HP motor, it increased the power by 8 HP at and above 5000 RPM I have not tested it on the car at the track, it(the test) was on my 518 that I ran the six pak on, I had switch intakes to a Team G dominator intake and tested several 1050 Dominator carbs, the six pak made 10 HP more(same torque ) than any of the 1050 Dominators did including the tests with the spacer
Re: Wilson Intake spacer [Re: WILD BILL] #878955
12/13/10 03:58 PM
12/13/10 03:58 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Wild Bill which one did you use....4150 or 4500?
Thanks, Don
Re: Wilson Intake spacer [Re: cudadon] #878956
12/13/10 04:04 PM
12/13/10 04:04 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
4150
Test were done on the first build we did. Intake was a Team G and the carb was my APD alky 950.
It was our intention to do some on track testing with it before I tried saving the $$$ for one but never got the chance due to my luck.
Re: Wilson Intake spacer [Re: Cab_Burge] #878957
12/13/10 04:33 PM
12/13/10 04:33 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
interesting as I'm going to run my 6-pack on my new motor even know everybody tells me I'll make more power w/ a single 950....
Coming soon!!!!
Re: Wilson Intake spacer [Re: Mr.Yuck] #878958
12/13/10 07:04 PM
12/13/10 07:04 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Thanks.
def worth the money,throttle resp and i got 15hp on my dyno pulls.alot of money but awesome piece mine was a 4hole 1" spacer
Re: Wilson Intake spacer [Re: fishy340] #878959
12/13/10 07:47 PM
12/13/10 07:47 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
What intake? The older 440-2 (4150 flange) intake show good improvement with the addition of a 4150/4500 adapter.
I done some testing with a 4" toilet with and without the adapter at the track back to back runs. The toilets holes are slotted which will accept both bolt patterns.
It was worth a few numbers on the time slip. BTW.
IMO the wilson is more or less a shot in the dark. Too many variables, cam size, intake plenum, piston speed. To say if the engine will respond with the spacers. I will say I have never seen one loose power though.
