I have to go back in and degree the cam on a poor running 340 and I just dread it! I have had issues with the front oil pan gasket popping completely out of place after assembly and other oil leak issues. I usually loosen a few oil pan bolts and wedge a couple of screwdrivers under the lip of the oil pan to pry it down a little, then install the cover. I don't think it would go on without this but maybe someone knows an efficient way to do this whole job, or at least doesn't dread it as much as I do/// Thanks for any helpful ideas.
