Re: 518 Swap PATC kit
[Re: way2fast]
#878820
12/13/10 10:58 AM
12/13/10 10:58 AM
Posts: 251 Lithonia, Ga
36PLYM
Lithonia, Ga
I have this same set up on my 36. I used GM #14014519 vacuum switch instead of the adjustable one, could never get that one to work right. If I understand the switch is normally open. At idle there is vacuum and the switch closes the circuit. The OD and lockup circuits should not be complete until the pressure switches close at whatever speed or pressure they are set for. I found the GM switch at pull a part. A lot of 80's vans used them. Look at the last picture on this link. Get the wiring hook up from the donor! http://www.73-87.com/7387garage/drivetrain/lockup.htm
36 Plymouth Coupe 318 w/360 heads 518 trans 8 3/4 rear Ga. Tech BCE'78
[Re: 36PLYM]
#878821
12/13/10 08:44 PM
12/13/10 08:44 PM
Posts: 219 Southwest
way2fast
Southwest
I searched for some other options before buying the PATC kit every trans shop I called was out of stock on the chevy switches, so I ended up just buying the PATC kit. I have emailed them ...but no reply.
Go Fast and Swerve!
[Re: way2fast]
#878822
12/13/10 11:33 PM
12/13/10 11:33 PM
Posts: 32,957 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
Switch should be hot on both sides with the engine running until you get on the gas enough to lower the vacuum below 4". That's the way my gm switch works to keep the od from kicking in and out while normally accelerating. You need power going to the SOLENOIDS or they won't engage the od and lock up. Vacuum drops when you get hard into the gas and opens the switch kicking out the od and lockup until you ease up on the go pedal. Then the vacuum goes up and od kicks back in.
[Re: stumpy]
#878827
12/14/10 05:31 PM
12/14/10 05:31 PM
way2fast
Southwest
I did use teflon tape on the switches... but the OD is engaging, although it is in-out-in-out-in-out which I assumed was either the TV cable adjustment or the vacuum switch adjustment. the 1-2-3 shift seems ok right now so I thought I would try adjusting the vacuum switch point.
Go Fast and Swerve!
