dana 60 parts in a 70? #878752
12/13/10 02:34 AM
12/13/10 02:34 AM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
i got around to looking at the dana i bought to have cut down its out of a 73 motor home on one of the braces it marked 70 so guiess its a dana70 insted of a 60 its got a 4.56 gear
havea few ???s
will 60 parts fit? ifso what kind of locker(no spool) will work? i had a buddy that had a racecar thad had a 60 in it with some sort of locker that would lock both axles if 1 tire spun till you back up then would be like a single track but i have no clue what it was called but kinda liked it asi want to drive on street so what locker would/should i be looking for?
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: dana 60 parts in a 70? [Re: toplescuda] #878753
12/13/10 09:21 AM
12/13/10 09:21 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
powerlock internals interchange.
powerlock case is bigger.
Have empty case available if you go that route.
Re: dana 60 parts in a 70? [Re: toplescuda] #878754
12/13/10 04:03 PM
12/13/10 04:03 PM
Sell the dana 70, if you can, and buy a Dana 60 I bought a cut down Dana 70 from Bob Mazzolini that came out of John Diana old modified Duster that Chrysler made for him with 7.17 gears in it( I installed some 5;13 in it), it was a heavy rascal The ring and pinion gears are not interchangeable and the Dan 70 has two completley different ring gear offsets buy a Dana 60
Re: dana 60 parts in a 70? [Re: Cab_Burge] #878755
12/13/10 09:31 PM
12/13/10 09:31 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
well crap least i dont have a lot in it lol
1971 charger
Re: dana 60 parts in a 70? [Re: toplescuda] #878756
12/13/10 09:48 PM
12/13/10 09:48 PM
Orlando Florida
blown572dart Offline
Orlando Florida
Put a 9inch in it
